MicroSD Size mismatch with Image
hi Montero65,
On the gnu+linux images that we control we are doing precisely as you suggest, now. In fact the gnu+linux images must be expanded in order to take full advantage of the space available on the full SD card.
The problem arises with the images that we do not control.
I will pass this on to the developers in our own think tank, and see what we can do to influence the people who are building the proprietary images for Android &c.  If I controlled it this would be fixed this afternoon. If TL Lim controlled it, it would have been fixed weeks ago.
The most important thing to do is to make sure that your SD card really has the capacity that it is supposed to have.  There are several on-line tests for this purpose.  If you have a bad or fraudulent card (maybe even a fake) there is no amount of programming that will fix that.
Another thing we can do is have a builld and test group of volunteers who will verify that each image will actually work with X number of SD card vendors and size. This is not fully in place, and we are going to have to discuss it some more.  In the mean time, the best i can suggest atm is to purchase quality cards which are having the capacity they advertise.
NOTE:  The 'K' problem is universal. Please don't shoot the messenger. developers *all* use K=1024...  SD card vendors all   ALL  use  K=1000.  This is clearly an error, but none of use who are developers are going to start using  K=1000 !!  (NOT GOING TO HAPPEN)   The reason of course is that K is about binary, not about decimal; and the even binary number closest to 1000 is  1024....   so, what's the 16Gb equivalent of this idea... ?
17,179,869,184
Do you see the problem ?  By the place value that we are talking about billions of bytes (16 Billion bytes) is actually well over seventeen billion bytes !!
The manufacture of these cards is in the hands of engineers who have NDAs and contracts with multiple Corporations... and our hands are tied.    Its not so simple as tell someone to make the image smaller... we get the image the way its given to us...   this problem can be pushed back a bit... but it is going to take some time, politics, understanding, and patience.
MicroSD Size mismatch with Image - by Hbtr - 07-30-2016, 08:31 PM
RE: MicroSD Size mismatch with Image - by Hbtr - 07-31-2016, 07:38 AM
RE: MicroSD Size mismatch with Image - by tllim - 08-01-2016, 02:11 PM
RE: MicroSD Size mismatch with Image - by Obewon - 08-04-2016, 04:47 PM
RE: MicroSD Size mismatch with Image - by tllim - 08-05-2016, 12:27 PM
RE: MicroSD Size mismatch with Image - by MarkHaysHarris777 - 08-05-2016, 08:50 AM
RE: MicroSD Size mismatch with Image - by DonFL - 08-05-2016, 01:43 PM
RE: MicroSD Size mismatch with Image - by tllim - 08-07-2016, 05:40 PM
RE: MicroSD Size mismatch with Image - by FoZo - 08-08-2016, 08:19 AM
  Reducing Android Image download size. KPhillisJr 4 8,213 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 6,439 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 23,443 05-05-2017, 01:50 AM
Last Post: Quezbeme
  Error formatting MicroSD Terra854 21 39,779 03-07-2017, 01:31 AM
Last Post: AnaNova
  android image & sd card size problems tomarneson 11 17,991 01-24-2017, 05:31 AM
Last Post: ayufan
  Tutorial: How to create DD images with appropriate size tkaiser 5 12,575 12-20-2016, 08:17 AM
Last Post: Bluphire
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,229 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 5,663 10-17-2016, 11:42 AM
Last Post: mathiraj
  burning Android SD image with Ubuntu... Jessica Spongekipper 0 2,099 09-16-2016, 01:46 AM
Last Post: Jessica Spongekipper
  Can't read SD card on Mac/Win after mounting DD Android image Voyager 3 5,606 09-04-2016, 12:05 PM
Last Post: Boring
