MicroSD Size mismatch with Image
Quote:
To me it seems they just made the img. file too large to fit most SD-cards  Huh
its actually the other way round. Many SD cards don't view a  'K' correctly.  A 'K' is supposed to be 1024 bytes.  Many SD card vendors view the 'K' as 1000 bytes.  To make things worse, often, sadly, the SD card is fraudulent by a certain percentage... so that its actually 'smaller' than it advertises even taken into account the 'K' size.
I highly recommend a good quality card from Samsung...  the Class ten (10) Evo+ cards, 32Gb, and get a card much larger than the image you're trying to write. When you're done you can expand the image partitions to the full size of the card, either with built-in tools, or with the 'gparted' program on a gnu+linux system.
Hope this is helpful.  Also, visit on the chat irc site.  Often its easier to help with this stuff on-line live than by playing forum tag...   Wink
MicroSD Size mismatch with Image - by Hbtr - 07-30-2016, 08:31 PM
RE: MicroSD Size mismatch with Image - by Hbtr - 07-31-2016, 07:38 AM
RE: MicroSD Size mismatch with Image - by tllim - 08-01-2016, 02:11 PM
RE: MicroSD Size mismatch with Image - by Obewon - 08-04-2016, 04:47 PM
RE: MicroSD Size mismatch with Image - by MarkHaysHarris777 - 08-05-2016, 12:27 AM
RE: MicroSD Size mismatch with Image - by tllim - 08-05-2016, 12:27 PM
RE: MicroSD Size mismatch with Image - by DonFL - 08-05-2016, 01:43 PM
RE: MicroSD Size mismatch with Image - by tllim - 08-07-2016, 05:40 PM
RE: MicroSD Size mismatch with Image - by FoZo - 08-08-2016, 08:19 AM
  Reducing Android Image download size. KPhillisJr 4 8,222 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 6,445 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 23,485 05-05-2017, 01:50 AM
Last Post: Quezbeme
  Error formatting MicroSD Terra854 21 39,862 03-07-2017, 01:31 AM
Last Post: AnaNova
  android image & sd card size problems tomarneson 11 18,016 01-24-2017, 05:31 AM
Last Post: ayufan
  Tutorial: How to create DD images with appropriate size tkaiser 5 12,586 12-20-2016, 08:17 AM
Last Post: Bluphire
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,267 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 5,671 10-17-2016, 11:42 AM
Last Post: mathiraj
  burning Android SD image with Ubuntu... Jessica Spongekipper 0 2,100 09-16-2016, 01:46 AM
Last Post: Jessica Spongekipper
  Can't read SD card on Mac/Win after mounting DD Android image Voyager 3 5,613 09-04-2016, 12:05 PM
Last Post: Boring
