MicroSD Size mismatch with Image
(08-04-2016, 04:47 PM)Obewon Wrote: I have tried 3 methods to burn android-ver5.1.1-20160711-pine64-64GB to a SanDisk 64 GB  microSDXC USC-1 card, all 3 (Windows Disk Imager, Phoenix  and Rufus) and they all gave me the message "Not enough available space on selected drive". The drive properties tells me I have 59.4 GB of available space . My question is why do we advertise the file is for a 64GB card and it won't FIT ? If there is a way to make it fit please tell me !
Same problem as me.
Found another thread (http://forum.pine64.org/showthread.php?tid=1674) but there is not much help there either in regards to a solution. To me it seems they just made the img. file too large to fit most SD-cards  Huh
Would really appreciate some help with this, and hopefully explained at a low-skill level type of way..
MicroSD Size mismatch with Image - by Hbtr - 07-30-2016, 08:31 PM
RE: MicroSD Size mismatch with Image - by Hbtr - 07-31-2016, 07:38 AM
RE: MicroSD Size mismatch with Image - by tllim - 08-01-2016, 02:11 PM
RE: MicroSD Size mismatch with Image - by Obewon - 08-04-2016, 04:47 PM
RE: MicroSD Size mismatch with Image - by Stiansen - 08-04-2016, 11:08 PM
RE: MicroSD Size mismatch with Image - by tllim - 08-05-2016, 12:27 PM
RE: MicroSD Size mismatch with Image - by DonFL - 08-05-2016, 01:43 PM
RE: MicroSD Size mismatch with Image - by tllim - 08-07-2016, 05:40 PM
RE: MicroSD Size mismatch with Image - by FoZo - 08-08-2016, 08:19 AM
  Reducing Android Image download size. KPhillisJr 4 10,074 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 7,477 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 28,237 05-05-2017, 01:50 AM
Last Post: Quezbeme
  Error formatting MicroSD Terra854 21 46,925 03-07-2017, 01:31 AM
Last Post: AnaNova
  android image & sd card size problems tomarneson 11 21,732 01-24-2017, 05:31 AM
Last Post: ayufan
  Tutorial: How to create DD images with appropriate size tkaiser 5 14,566 12-20-2016, 08:17 AM
Last Post: Bluphire
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 29,459 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 6,613 10-17-2016, 11:42 AM
Last Post: mathiraj
  burning Android SD image with Ubuntu... Jessica Spongekipper 0 2,531 09-16-2016, 01:46 AM
Last Post: Jessica Spongekipper
  Can't read SD card on Mac/Win after mounting DD Android image Voyager 3 6,881 09-04-2016, 12:05 PM
Last Post: Boring
