bluetooth wifi bugs
It shall be noted that WiFi and Bluetooth are handled by the same chip on the PinePhone (and also on the PinePhone Pro, though it is a different chip than on the original PinePhone), which is why there is only one hardware kill switch for both. So if you turn off only WiFi or Bluetooth in software, the chip will by design still be operating to handle the other one. Only turning both off can possibly power down the chip altogether, though I do not know whether that is the case, and as @KC9UDX has pointed out, you should not take my word for it either way anyway.
bluetooth wifi bugs - by aular - 08-23-2023, 06:18 PM
RE: bluetooth wifi bugs - by Kevin Kofler - 08-23-2023, 07:11 PM
RE: bluetooth wifi bugs - by KC9UDX - 08-23-2023, 11:38 PM
RE: bluetooth wifi bugs - by aular - 08-24-2023, 06:55 AM
RE: bluetooth wifi bugs - by KC9UDX - 08-24-2023, 03:32 PM
RE: bluetooth wifi bugs - by Kevin Kofler - 08-24-2023, 07:37 PM
RE: bluetooth wifi bugs - by aular - 08-27-2023, 07:53 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 618 02-17-2024, 04:15 PM
Last Post: vortex
Question bluetooth speakers and pinephone pro Supervisor 2 1,308 01-30-2023, 09:21 AM
Last Post: Supervisor
  No wifi/bluetooth on multiple OS's Xxancap15 1 1,172 10-28-2022, 12:10 PM
Last Post: fxc
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,449 08-29-2022, 02:46 PM
Last Post: emsyr
  Why not Atheros ath9k_htc for wifi? altulke 13 6,895 08-11-2022, 01:01 PM
Last Post: auanta
  Did i break my wifi with the keyboard? captchasolver 5 3,288 02-10-2022, 03:39 PM
Last Post: pothos
  Wifi doesn't respond jmlich 6 4,333 02-04-2022, 06:50 PM
Last Post: bcnaz
  Suddenly WiFi signal strength is poor cinix 4 3,599 09-26-2021, 04:19 PM
Last Post: cinix
  Wifi/BT interface not detected aithal 17 15,108 05-30-2021, 11:10 AM
Last Post: Krasimir
  WIFI not available after anx7688 update failure frimmel 21 19,921 05-11-2021, 02:45 AM
Last Post: frimmel
