bluetooth wifi bugs
(08-24-2023, 06:55 AM)aular Wrote:
(08-23-2023, 11:38 PM)KC9UDX Wrote: When you turn the kill switch off, the only kind of malfunction that could cause the modern to work is a short circuit.  Statisticaly, the kind that if you had one, it would cause other problems first.  Frankly, the level of security you are seeking can only be obtained by taking charge yourself.  Understand the hardware and software to the point you could actually hack it yourself; then you will have what you are looking for.
What ment by turning off the bluetooth and wifi is by keeping the hardware switch in the up position on the back of the phone but on the screen you can see the icons but they have that off or line saying they are off. Thats what i want to know and have some suspicions that the software may say they are off but it might really be on still allowing anybody with the right tools to connect to it.
And that's precisely why you need to understand the hardware and software for yourself.  If you don't trust us to tell you the modem can't work with the privacy switch in the off position, then you really can't trust anyone to tell you anything else you'd like to hear about it. Nor should you.  Take your security into your own hands.
:wq
[ SRA accepts you ]
bluetooth wifi bugs - by aular - 08-23-2023, 06:18 PM
RE: bluetooth wifi bugs - by Kevin Kofler - 08-23-2023, 07:11 PM
RE: bluetooth wifi bugs - by KC9UDX - 08-23-2023, 11:38 PM
RE: bluetooth wifi bugs - by aular - 08-24-2023, 06:55 AM
RE: bluetooth wifi bugs - by KC9UDX - 08-24-2023, 03:32 PM
RE: bluetooth wifi bugs - by Kevin Kofler - 08-24-2023, 07:37 PM
RE: bluetooth wifi bugs - by aular - 08-27-2023, 07:53 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 650 02-17-2024, 04:15 PM
Last Post: vortex
Question bluetooth speakers and pinephone pro Supervisor 2 1,328 01-30-2023, 09:21 AM
Last Post: Supervisor
  No wifi/bluetooth on multiple OS's Xxancap15 1 1,185 10-28-2022, 12:10 PM
Last Post: fxc
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,461 08-29-2022, 02:46 PM
Last Post: emsyr
  Why not Atheros ath9k_htc for wifi? altulke 13 6,965 08-11-2022, 01:01 PM
Last Post: auanta
  Did i break my wifi with the keyboard? captchasolver 5 3,323 02-10-2022, 03:39 PM
Last Post: pothos
  Wifi doesn't respond jmlich 6 4,379 02-04-2022, 06:50 PM
Last Post: bcnaz
  Suddenly WiFi signal strength is poor cinix 4 3,631 09-26-2021, 04:19 PM
Last Post: cinix
  Wifi/BT interface not detected aithal 17 15,205 05-30-2021, 11:10 AM
Last Post: Krasimir
  WIFI not available after anx7688 update failure frimmel 21 20,051 05-11-2021, 02:45 AM
Last Post: frimmel
