NomadNet (e2e mesh comms via BT/WiFi/LoRa)
(02-17-2023, 12:41 PM)reTestability Wrote: Are you always booting from the SD card ?
Yes. I may have had the KDE issue you were mentioning that soured me on Manjaro and always went the Arch Phosh on SD card route, however Manjaro Phosh (updated 2/17/23) is KDE-free and a bit bloated, but over all looks good for this RNS install test.
To make it easy, I went the SD card route and once I get this working, I might try your suggested method for booting directly from the PP without an SD card.
The results are below and it's actually the same issue I ran into when trying to put RNS on Arch awhile back which likely means if this gets figured out, it means RNS will work on Arch in addition to Manjaro.
Here's what I got following your instructions
STEP 1:
sudo pacman -S pinephone-devtools
RESULT=
"error: target not found: pinephone-devtools"
STEP 2:
sudo pacman -S python-pip
RESULT=
SUCCESS
STEP 3:
pip3 install rns
RESULT=
[A lot of info about missing pieces related to netifaces. I couldn't figure out how to copy paste the read out from terminal to gedit to download and repost so below is the final error message]
"note: This error originates from a subprocess, and is likely not a problem with pip.
  ERROR: Failed building wheel for netifaces
Failed to build netifaces
ERROR: Could not build wheels for netifaces, which is required to install pyproject.toml-based projects"
RE: NomadNet (e2e mesh comms via BT/WiFi/LoRa) - by PineFone - 02-19-2023, 10:31 AM
  Flight mode turns off wifi but not the modem (cellular) jojuma 2 3,489 02-28-2023, 01:58 PM
Last Post: calinb
  No wifi with phosh image wave22 3 4,963 02-15-2022, 07:25 AM
Last Post: wave22
  WiFi Calling ? User 22007 5 8,918 07-19-2021, 11:17 PM
Last Post: KNERD
  WiFi fun on a new PinePhone ~Daniel~ 3 5,867 06-30-2021, 07:20 AM
Last Post: mouffa
