Help with ssh and setting default apps
(09-10-2022, 07:22 AM)jojuma Wrote: Hello,
while setting up postmarketos on pinephone I encountered some problems, I don't get along with.
Probably the easier one: I try to access the PP shell via SSH like described on https://wiki.postmarketos.org/wiki/SSH.
The password should be the same like I use for sudo commands, right? But whatever I try, my password is not correct...
Secondly I'm trying to set a default app as video player.
I tried using the xdg-mime command like described on https://wiki.alpinelinux.org/wiki/Default_applications.
But it says
/bin/ash: xdg-mime: not found
What am I supposed to do about this? xdg-utils should be working, shouldn't it? Or is this about "ash" and "bash"?
I'd be grateful for any hints
usually user name is required and for pmos it is "user", mobian has "mobian", archlinux has "alarm" and manjaro has "manjaro".
$ ssh -p 22 user@ip-number-or-hostname
although in pinephone, i found out that authentication module crashes or malfunctions some cases, so reboot is required.
pmos has firewall activated by default, so it might cause some blocks. proper way is to add necessary holes to the firewall rules. but if lazy.
## disables firewall, not necessarily good idea for some.
$ sudo service nftables stop
for that default app, i cannot give direct advice but in my knowledge it is handled by gnome components, maybe gsettings.
RE: Help with ssh and setting default apps - by zetabeta - 09-10-2022, 07:42 AM
  Firefox Crashes on Start-up (latest installer) & How do I change Default Browser? aLoop100o 1 440 11-22-2023, 10:16 AM
Last Post: zetabeta
  How to choose which Waydroid Apps can appear on PostmaketOS Home Screen? Avisando 6 2,331 05-28-2023, 10:54 PM
Last Post: Avisando
  Unable to set default apps Barugon 7 3,395 12-04-2022, 12:28 PM
Last Post: alaraajavamma
  closing apps rather than leaving them running (phosh) lordearl 7 6,226 02-03-2022, 09:14 PM
Last Post: parry
  What is the default pin!? ThatWasLeftHanded 3 5,496 09-08-2021, 09:01 AM
Last Post: walter1950
  Disabe Bluetooth by default Alejandro.SU 1 2,595 11-09-2020, 10:59 AM
Last Post: Lousy Fisherman
  What is default password? quixote 6 17,950 11-03-2020, 08:55 AM
Last Post: wibble
  Phone arrived: Stupid Questions begin. Setting up OpenVPN? OLOV 3 4,688 10-06-2020, 05:10 PM
Last Post: OLOV
  Resize apps for postmarket OS zeb11 8 10,714 09-26-2020, 04:21 PM
Last Post: ragreenburg
  More Apps! Zweitaktmotor 6 7,291 03-24-2020, 04:59 AM
Last Post: PureTryOut
