pmos/phosh edge update and audio disappears
(06-30-2022, 08:15 PM)robthebold Wrote: I today updated pmos/phosh edge and now I don't have audio. There used to be an "Internal Speaker" option in the audio output of settings|sound, but now the only choice is "Analog Output - sun9i-hdmi." So this means no audio in/out for phone/web/apps/etc.
I thought it was this again: https://postmarketos.org/edge/2021/04/15...ire-pulse/
but that's not the fix this time. Pipewire-pulse doesn't seem to be the culprit. And I can pop in an old SD card with un-updated OS and audio is fine(ish) so it's not hardware suddenly flaking out.
Ideas? (Thanks in advance . . .)
It is due to the update of alsa-lib from 1.2.6 to 1.2.7. There is a fix in the works, but unknown when it will be available. If you can't wait for the fix, you can downgrade alsa-lib and alsa-ucm-conf back to 1.2.6 apk add /var/cache/apk/alsa-lib-1.2.6<tab> and then apk add /var/cache/apk/alsa-ucm-conf-1.2.6<tab>
RE: pmos/phosh edge update and audio disappears - by mark1250 - 07-01-2022, 06:38 AM
  Fresh install pmos+phosh does not boot user641 1 638 10-08-2023, 04:04 AM
Last Post: user641
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 988 10-03-2023, 06:32 PM
  [Not Pinephone] Phosh Autologin LienRag 11 2,437 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  installed postmarketos v23.06 no audio samlo 1 907 07-14-2023, 12:53 AM
Last Post: samlo
  Boots To Shell After Dead Battery (PMOS) britelite 0 811 02-17-2023, 02:41 PM
Last Post: britelite
  No Application Data PMOS 21.12.1 Captain1ndustry 4 4,010 08-12-2022, 07:42 AM
Last Post: Gon
  How to delete single sms in phosh? bircoph 1 1,437 07-06-2022, 08:10 AM
Last Post: bircoph
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 2,787 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  Report from the bleeding edge: calling / texting jmorris 38 39,067 05-01-2022, 10:00 PM
Last Post: jmorris
  closing apps rather than leaving them running (phosh) lordearl 7 6,437 02-03-2022, 09:14 PM
Last Post: parry
