SATA controller problem
What distribution/kernel version are you using? Also which precise Quartz64 board?
One potential issue on the Quartz64 Model A is that the 3.3V regulator for PCIe only provides up to 10W, so if the card draws more than that through the 3.3V PCIe rail it's going to keep resetting from voltage drop. Another issue is the PCIe reg ranges for which the fix never made it upstream properly, I don't think.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
SATA controller problem - by tobs - 06-04-2022, 02:29 PM
RE: SATA controller problem - by vs_cy - 02-15-2023, 04:29 AM
RE: SATA controller problem - by CounterPillow - 02-15-2023, 07:58 AM
RE: SATA controller problem - by vs_cy - 02-15-2023, 08:07 AM
RE: SATA controller problem - by CounterPillow - 02-15-2023, 09:42 AM
RE: SATA controller problem - by vs_cy - 02-15-2023, 01:14 PM
RE: SATA controller problem - by CounterPillow - 02-15-2023, 09:19 PM
RE: SATA controller problem - by vs_cy - 02-16-2023, 04:47 AM
RE: SATA controller problem - by vs_cy - 03-14-2023, 01:36 PM
RE: SATA controller problem - by CounterPillow - 03-17-2023, 01:08 PM
  Quartz64 Model A - SATA & USB3 dml-pc 0 1,255 10-13-2022, 07:43 PM
Last Post: dml-pc
  SATA SSD and case? MikeInMass 2 3,745 07-10-2021, 07:30 PM
Last Post: zer0sig
