PinePhone Pro not detected by my PC
(05-23-2022, 01:15 AM)fxc Wrote:
(05-22-2022, 10:03 PM)Syndicator Wrote:
(05-22-2022, 04:53 PM)fxc Wrote: I think you're trying to boot an image for the regular PinePhone here. Trying to boot images for the regular PinePhone such as "JumpDrive" won't work on the Pro. Mind that you need to download your images via https://wiki.pine64.org/wiki/PinePhone_P...e_Releases.
For reflashing the eMMC you don't use MTP. Instead you boot an OS via the microSD card (for example Manjaro) and then you write the image directly to the eMMC from within that booted OS, for example using "dd". I would recommend to follow the instructions here: https://wiki.pine64.org/wiki/PinePhone_P...o_the_eMMC
Update I dd'd the Manjaro phosh to the eMMC and well now it doesnt load at all it wont even boot from SD card now. It stays stuck loading I'll post a picture later I'm too tired to keep dealing with this need to get up early for work.
Thanks for making me realize my error though fxc.
You can simply boot from microSD card again and "dd" again, just select the microSD card at boot using Tow-Boot. Make sure you're unpacking the archive and that you flash to the whole drive, instead of partition 1. Best if you write the exact command you use here.
I cannot boot from SD card. I would post the images  here but they're too large evidently I'm not able to post anything above 500kb.
I used this
sudo dd if=IMAGE.img of=/dev/mmcblk2 bs=1M status=progress conv=fsync
followed the instructions to the T. When I boot normally and try to boot holding the power and vol+ I do get a sligthly diff error but I cannot boot all the same.
EDIT: upon rereading the instructions I realize what I did wrong.  I didn't wipe the bootloader from the eMMC using
sudo dd if=/dev/zero of=/dev/mmcblk2 seek=64 count=400 conv=fsync
Aigh that's what I get for not taking a step away after being frustrated and being given the simple answer.
I am guessing there is no solution to this.
RE: PinePhone Pro not detected by my PC - by fxc - 05-22-2022, 04:53 PM
RE: PinePhone Pro not detected by my PC - by fxc - 05-23-2022, 01:15 AM
RE: PinePhone Pro not detected by my PC - by Syndicator - 05-28-2022, 08:35 PM
RE: PinePhone Pro not detected by my PC - by fxc - 05-29-2022, 09:52 AM
RE: PinePhone Pro not detected by my PC - by fxc - 05-30-2022, 02:37 AM
RE: PinePhone Pro not detected by my PC - by fxc - 06-09-2022, 11:05 AM
RE: PinePhone Pro not detected by my PC - by fxc - 06-08-2022, 04:44 AM
  Pinephone pro replacement lcd screen Linuxuser3 0 227 04-27-2024, 05:42 AM
Last Post: Linuxuser3
Question Pinephone Pro for a Debian user? primesocial 2 299 04-15-2024, 03:01 AM
Last Post: zetabeta
  PinePhone Pro silver lining, it’s fast, real damn fast ashoka232 0 595 03-20-2024, 01:45 AM
Last Post: ashoka232
  PinePhone Pro Black Screen CrimsenRaven 2 496 03-16-2024, 11:40 AM
Last Post: tmoj
  PinePhone Pro Review tmoj 2 887 03-14-2024, 07:14 AM
Last Post: tmoj
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 835 02-17-2024, 04:04 AM
Last Post: fxc
Question Phone call with the pinephone pro dfs 5 4,434 02-10-2024, 09:54 PM
  Average Joe review of Pinephone Pro (March 2023) alaraajavamma 6 10,643 01-06-2024, 11:32 AM
Last Post: mikehenson
Question T-Mobile and Pinephone Pro in the US jydoxcen 4 980 01-02-2024, 09:08 AM
  Pinephone Pro Screen Protector jydoxcen 11 1,657 12-21-2023, 07:58 AM
Last Post: zetabeta
