Just got my Pinecil
(03-15-2022, 09:11 PM)donwynne Wrote: Hey all.
[color=#666666]I just got my Pinecil.  Immediately hooked it up to PD and tested it.  I'm impressed at how quickly it heats up given the wattage I allocated to it.  (I went into advanced settings and limited it to 15 watts, mostly to compare it to a similar-sized soldering pencil I had lying around.)  I did notice one thing odd though.  I didn't use it for very long (just long enough to dip the tip in some tinning compound and clean it), but the space around the "+" button seemed to get noticeably warm.  Not burning hot, mind you, but given that the housing is made out of plastic, it got warm enough to make me wonder how hot the components underneath were getting.  Anyone else noticed this?  Should I be concerned?
Don
Mine is  dead after using it for 3-4 times... crappy product
Just got my Pinecil - by donwynne - 03-15-2022, 09:11 PM
RE: Just got my Pinecil - by bbeeast - 04-22-2022, 07:01 AM
  Question about firmware updates on Pinecil V2 helengrace 1 449 10-16-2025, 10:41 PM
  incorporate a multimeter into the Pinecil kellanphil 2 2,184 08-13-2025, 01:14 AM
Last Post: lalisa12
Lightbulb Pinecil -> Pinegun? Avamander 21 33,873 01-21-2025, 01:09 PM
  Will the Pinecil work for repairing iPods, in particular the 30pin port connector? drewdavis 0 1,107 08-27-2024, 08:01 PM
Last Post: drewdavis
Exclamation What is this - Pinecil V3? andrea6 2 14,762 12-19-2022, 08:11 PM
  on pinepower, pinecil stopped working.. sanderboer 1 2,681 09-23-2022, 03:47 AM
  Pinecil Broken? skaaq 4 9,222 01-25-2021, 11:28 AM
Last Post: skaaq
  Pinecil stuck in shipping? mbreese 3 7,023 01-07-2021, 07:46 AM
Last Post: moxx
  Pinecil - Tip Disconnected molzy 2 6,949 01-03-2021, 07:21 AM
Last Post: molzy
  Pinecil arrived VaZso 0 3,110 12-28-2020, 10:36 AM
Last Post: VaZso
