Freecad on the PBP
have you tried installing python-is-python3? iirc it's intended for this exact kind of use case where a user app uses an older python, but the base system uses a newer python.You likely won't have any luck with an x86 version on a PBP, instead try using pamac to look through the AUR for FreeCAD, and edit/check the build file to ensure aarch64 is included in the supported architectures. (yay can also do this automatically, if it doesn't see your architecture in the build file, it will prompt you if you you'd like it to try and build for it.)
Freecad on the PBP - by flatulent_piney - 02-15-2022, 07:02 AM
RE: Freecad on the PBP - by tophneal - 02-15-2022, 02:37 PM
RE: Freecad on the PBP - by TRS-80 - 02-17-2022, 11:06 PM
