Keyboard case not charging (or not working) and a possible FIX for both
(04-25-2022, 04:04 AM)Humid Stylus Wrote: Since I thought I saw a slight bulge I got suspicious of the plastic "guide" pin in the shell. It would make sense since it seems the pogos closest to it has the problems.
So I took a knife and remove a few millimeters of the plastic guide pin and now my keyboard shell seems to work as it should.
Thanks for this suggestion.
I started having the same problem with the keyboard not connecting to the PinePhone today. I came to the same conclusion after having no success with contact cleaner and reinstalling the PinePhone a couple of times. If I pressed on the back of the case directly above the pogo pins it would connect, but only while I kept pressing. I was looking at the keyboard case where the pogo pins connect and also noticed the rectangular locating pin. After reading your comment I used a sharp craft knife and shaved a fraction of a mm off the pin. It now connects easily with both keyboard and power.
A warning - by pifou - 02-15-2022, 03:49 PM
RE: Keyboard case not charging (or not working) and a possible FIX for both - by ajs - 05-01-2022, 09:48 PM
  Case for Pinephone totilele 13 7,643 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 312 03-03-2024, 04:55 PM
Last Post: jakfish
  keyboard case charging but not typing new2pinephone 18 6,027 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,913 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 457 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,297 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 481 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,300 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 548 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 648 10-21-2023, 02:55 AM
