gpsd issues
The modem presents multiple USB ports with different uses. IIRC ttyUSB1 is NMEA output only, while ttyUSB2 is used for the AT commands that control it. Some modem failure modes cause one or more of the USB ports to disappear until the modem is restarted. You don't mention whether you're checking the NMEA output to see if it's getting a fix before you start gpsd. I don't know if the AGPS is now handled automatically or whether you'll need to do that manually, but without it you need a clear sky view, patience and luck to get a fix at all. Some people have trouble getting a fix even with the AGPS working. I don't remember what I did to get gpsd working while ModemManager was running - I'll see if I can find anything in my notes.
gpsd issues - by io. - 02-03-2022, 02:00 PM
RE: gpsd issues - by wibble - 02-04-2022, 09:33 AM
RE: gpsd issues - by jhasler - 05-05-2022, 04:06 PM
RE: gpsd issues - by wibble - 05-06-2022, 04:58 AM
RE: gpsd issues - by jhasler - 05-06-2022, 06:20 AM
RE: gpsd issues - by wibble - 05-07-2022, 03:31 AM
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 4,876 09-23-2022, 05:15 AM
  Lot of issues after flashing mobian to emmc with tow-boot benedikt55 5 2,723 08-30-2022, 01:14 PM
Last Post: benedikt55
  Issues with Mobian? Start here. tophneal 0 5,060 04-21-2022, 11:27 AM
  Anyone find a work around for the brightness issues from kernels 5.13/14? ragreenburg 2 2,414 09-01-2021, 08:49 AM
Last Post: ragreenburg
  Remote desktop, video playback issues Zebulon Walton 13 11,115 06-17-2021, 06:57 AM
Last Post: aus
  Always-On VPN issues at boot. Need to manually activate it.. What did i miss.. temp0rary 0 1,400 05-31-2021, 10:35 AM
Last Post: temp0rary
  Issues with Mobian 20210314 (data and updates) IMSAI8080 5 6,189 03-20-2021, 04:14 AM
Last Post: IMSAI8080
  Mobian Issues Csanderson0313 13 12,214 03-02-2021, 04:57 AM
Last Post: Gribouille
