No update PGP, Error Solved
ok.. thanks
i know this is not the way, but
i already try this:
pacman-key --init
pacman-key --populate archlinuxarm manjaro manjaro-arm
and refresh and other command but the same result error and error.
this one sudo pinephonepro-post-install
didn't find it... i'll keep this info.
i just install 2 packages without the .sig
well. i guest what i did was a dumb move.
i'll try to reinstall with the sig.. let see what happen.
thanks Luziferus for the info.
No update PGP, Error Solved - by iopser - 01-31-2022, 05:15 PM
RE: No update PGP, Error Solved - by Luziferus - 02-01-2022, 05:28 AM
RE: No update PGP, Error Solved - by iopser - 02-01-2022, 07:53 AM
  Arch SXMO Stopped Booting After A Megi Linux Update. mburns 0 468 11-07-2023, 09:52 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 607 10-14-2023, 11:57 AM
Last Post: mburns
  Cannot update new PinePhone Pro bent 6 3,518 05-15-2023, 02:43 PM
Last Post: alaraajavamma
  No display on early boot after Manjaro update robocone 0 854 07-07-2022, 05:47 AM
Last Post: robocone
  Offline Updates Error dgiffin 7 4,689 06-30-2022, 02:19 PM
Last Post: magdesign
  Manjaro Plasma Beta 11 sleep issue after 3/22 update Fred Zyphal 6 3,970 05-22-2022, 12:37 PM
  Manjaro update, no boot, just noise. wilmarcdw 2 1,684 05-09-2022, 07:24 AM
Last Post: wilmarcdw
Question System Updates: "unexpected error" Greendrake 6 4,344 03-05-2022, 05:15 AM
Last Post: Greendrake
  Manjaro-phosh beta 22 release won't boot after update tckosvic 1 1,531 02-28-2022, 09:46 AM
Last Post: tckosvic
  Error Updating Emilio 2 2,148 02-20-2022, 09:51 AM
Last Post: Emilio
