No update PGP, Error Solved
Helloo
Today finallyyy a get this peace of hardware.
And when i try to update. oo error ... and error after error.
Well after reading researching, 2 h later i figure out one way to solve the issue.
The error pgp refer to the sig files, so i erase the sig file.
1 file error: archlinux-keyring-20220118-1any.pkg.tar.xz.sig or some like that.
2 file error: archlinuxarm-keyring-20140119-1any.pkg.tar.xz.sig or some like that.
make sudo pacman -Syu, make error happen, but dont erase the files. go to
/var/cache/pacman/pkg/ an erase the .sig, this is important.
and them install the package
sudo pacman -U /var/cache/pacman/pkg/package1.pkg.tar.xz
and try if you get another error like me, them
sudo pacman -U /var/cache/pacman/pkg/package2.pkg.tar.xz
After that you can try to install openssh or one prog o just try and update.
For me this solve this litlle problem. and system update DONE.
ello
Saludos.
No update PGP, Error Solved - by iopser - 01-31-2022, 05:15 PM
RE: No update PGP, Error Solved - by Luziferus - 02-01-2022, 05:28 AM
RE: No update PGP, Error Solved - by iopser - 02-01-2022, 07:53 AM
  Arch SXMO Stopped Booting After A Megi Linux Update. mburns 0 466 11-07-2023, 09:52 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 603 10-14-2023, 11:57 AM
Last Post: mburns
  Cannot update new PinePhone Pro bent 6 3,515 05-15-2023, 02:43 PM
Last Post: alaraajavamma
  No display on early boot after Manjaro update robocone 0 850 07-07-2022, 05:47 AM
Last Post: robocone
  Offline Updates Error dgiffin 7 4,688 06-30-2022, 02:19 PM
Last Post: magdesign
  Manjaro Plasma Beta 11 sleep issue after 3/22 update Fred Zyphal 6 3,967 05-22-2022, 12:37 PM
  Manjaro update, no boot, just noise. wilmarcdw 2 1,683 05-09-2022, 07:24 AM
Last Post: wilmarcdw
Question System Updates: "unexpected error" Greendrake 6 4,344 03-05-2022, 05:15 AM
Last Post: Greendrake
  Manjaro-phosh beta 22 release won't boot after update tckosvic 1 1,529 02-28-2022, 09:46 AM
Last Post: tckosvic
  Error Updating Emilio 2 2,148 02-20-2022, 09:51 AM
Last Post: Emilio
