charging indicator
(01-28-2022, 02:48 PM)FrozenPine Wrote:
(01-28-2022, 02:15 PM)nristen Wrote: Does the PPP have a charding indicator that comes on when the phone is connected to a charger?
My PPP does not show any indication of being charged when connected to any charger I have tried.  I believe the battery is completely dead.
I have switched the audio out to UART and if I plug headphones into the jack and plug headphones in there is usually some activity followed by a regular pulse when connected to a charger.
When my PPP is plugged in while off, the light turns red briefly, and there is a long vibration. It does not have a hardware indication of charging while powered on, only the software battery indicator.
NOTE: If the PPP just arrived, and you haven't cracked the back yet, you will have to open it up and remove a plastic tab behind the battery before it will boot for the first time.
Thanks for your response.
After I received the PPP, I was able to power it on.  After it was on, every time the screen would go blank though, the only way that I found to get it back was to remove and replace the battery and hold the power button for two seconds.  An update from discover failed so I tried doing pacman -Syu from the terminal which worked however after every reboot, I told me that the last upgrade had failed and asked if I wanted to recover.  Throughout this process the battery kept getting lower and lower sometimes going down a percentage point every 10 seconds.
Since this I have not been able to get any response even when connected to a charger.
charging indicator - by nristen - 01-28-2022, 02:15 PM
RE: charging indicator - by FrozenPine - 01-28-2022, 02:48 PM
RE: charging indicator - by nristen - 01-28-2022, 04:11 PM
RE: charging indicator - by timonoj - 01-29-2022, 12:46 AM
RE: charging indicator - by thismarty - 01-30-2022, 12:29 PM
RE: charging indicator - by captainmorgan - 01-30-2022, 01:58 PM
RE: charging indicator - by thismarty - 01-30-2022, 03:00 PM
RE: charging indicator - by frankt - 01-30-2022, 06:29 PM
RE: charging indicator - by nristen - 01-30-2022, 07:08 PM
RE: charging indicator - by bcnaz - 01-31-2022, 04:54 AM
RE: charging indicator - by nristen - 01-31-2022, 06:05 PM
RE: charging indicator - by bcnaz - 01-31-2022, 07:20 PM
RE: charging indicator - by nristen - 02-01-2022, 09:04 AM
RE: charging indicator - by bcnaz - 02-02-2022, 05:28 AM
RE: charging indicator - by phelion - 02-02-2022, 09:01 AM
RE: charging indicator - by nristen - 02-03-2022, 01:31 PM
RE: charging indicator - by phelion - 02-03-2022, 04:36 PM
  PinePhonePro turns on when connecting usb charging cable xt0 5 1,070 10-10-2023, 12:01 PM
Last Post: zetabeta
  New out of box phone, vibrates and solid red light on charging StuckInTheCloud 1 924 03-24-2023, 03:12 PM
Last Post: fxc
Question Battery not charging when run down to 0. iwm 2 1,891 02-08-2022, 10:45 AM
Last Post: mburns
  USB to PC connection not charging PPP tckosvic 0 897 02-01-2022, 05:40 PM
Last Post: tckosvic
