write SD with UMS enabler and manjaro graphic bug in configuration
OK - I think there are 2 options:
1) Your flashing of new images is flawed
2) The SDcard slot is broken.
Most likely option 1 is the problem, but to eliminate option 2, when you have an SDcard installed and the phone boots Manjaro, can you see anything on the SDcard? 1 way to do this would be to open a terminal and type sudo blkid as follows
$ sudo blkid
[sudo] password for csn:
/dev/mmcblk2p2: LABEL="rootfs" UUID="55b74abb-ba72-413d-96f5-bd70f0971abf" BLOCK_SIZE="4096" TYPE="f2fs" PARTUUID="96cc52eb-02"
/dev/mmcblk2p1: LABEL="boot" UUID="a75a51ff-5a32-4cd3-984b-f9de3616f341" BLOCK_SIZE="1024" TYPE="ext4" PARTUUID="96cc52eb-01"
/dev/mmcblk0p1: SEC_TYPE="msdos" UUID="F2B1-AB9A" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="3a2db009-01"
/dev/mmcblk0p2: UUID="aa77e85c-8445-4c1c-b867-2ca993ac1a93" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3a2db009-02"
/dev/zram0: LABEL="zram0" UUID="3ac6945c-bc2a-413e-b495-85f94caa5e8d" TYPE="swap"
If you see anything on /dev/mmcblk0 then that is the SDcard and it indicates the hardware is OK. If not, try again with any SDcard with photos or music or anything on it.
RE: I am lost I can't boot to SD - by dukla2000 - 12-14-2021, 02:50 PM
RE: I am lost I can't boot to SD - by dukla2000 - 12-15-2021, 03:09 AM
RE: I am lost I can't boot to SD - by dukla2000 - 12-15-2021, 01:39 PM
RE: I am lost I can't boot to SD - by bcnaz - 12-15-2021, 12:42 AM
RE: I am lost I can't boot to SD - by tophneal - 12-15-2021, 02:24 PM
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 3,108 12-05-2024, 06:42 AM
Last Post: gilford
  box86 Actually Works Well on Manjaro Phosh/xfce jakfish 9 8,669 06-30-2024, 12:26 AM
Last Post: Peter Gamma
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 7,127 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  Can't get through "User Configuration" on new PinePhone a-l 24 31,478 06-01-2023, 10:08 AM
Last Post: feketej
  no sdcard boot and manjaro update failed Gwen 3 3,995 11-27-2022, 07:56 AM
Last Post: fxc
  Manjaro phosh no screen rotation sandspur 1 3,089 06-23-2022, 01:02 AM
Last Post: rapp
  Manjaro on Pinephone freezes during startup LasVegasLee 1 3,035 03-22-2022, 06:48 AM
Last Post: acrux
  Camera on manjaro arm transfer76 7 9,596 03-18-2022, 10:11 PM
Last Post: Ant
  PinePhone Stuck in landscape (Manjaro Plasma) Ephraimlad 1 2,841 01-04-2022, 05:41 PM
Last Post: jasonriedy
Wink Manjaro unlock code out of the box Red10Para 3 4,983 11-29-2021, 09:43 AM
Last Post: Red10Para
