Browser cog - Problems on Mobian
(12-12-2021, 12:54 PM)arno_nuehm Wrote:
(12-09-2021, 07:34 PM)TRS-80 Wrote: Are you still on Bullseye (Debian Stable)?
A quick search of Debian packages shows that's the latest supported version in that release.
Thanks for your answer.
I'm on Bookworm and all the versions following 0.8.1 are not working.
I had the same issue and was dying without cog.  Building latest from source got it going again.
  1. uninstall existing cog version (sudo apt remove cog)
  2. checkout latest version from https://github.com/Igalia/cog (git clone "https://github.com/Igalia/cog.git")
  3. install dependencies (sudo apt install cmake build-essential pkg-config libcairomm-1.0-dev libwayland-client++0 libinput-dev libgbm-dev libdrm-dev libepoxy-dev libwayland-dev libwpewebkit-1.0-dev  libsoup2.4-dev  libgio3.0-cil-dev  libgio2.0-cil-dev  libwpebackend-fdo-1.0-dev )
  4. build and install:
  5. cd cog
  6. cmake .
  7. make
  8. make install
Did the trick for me, hope it helps!
Browser cog - Problems on Mobian - by arno_nuehm - 12-09-2021, 04:13 AM
RE: Browser cog - Problems on Mobian - by TRS-80 - 12-09-2021, 07:34 PM
RE: Browser cog - Problems on Mobian - by red75user - 01-29-2022, 06:38 AM
RE: Browser cog - Problems on Mobian - by pothos - 02-10-2022, 03:27 PM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 21 2,160 5 hours ago
Last Post: anonymous
  Mobian repository status henrythemouse 16 8,830 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 140 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,022 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,842 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,945 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,912 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 638 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,046 06-19-2023, 03:02 PM
Last Post: vusra
