Battery life: Maybe really a hardware issue?
(09-08-2021, 06:23 AM)KNERD Wrote: Okay, it's been about 10 hours. I turned the phone back and and the battery level has not changed.
I guess this confirms the modem is still draining power from the battery even while turned off.
I thought that was most likely, just wasn't sure if the kill switch would prevent it. I'll keep the battery out when the phone isn't going to be used. Since the back has to be taken off anyway to get to the switches I figure that's best to reduce wear on the switch pack. (I don't know how many on/off cycles those dip switches are rated for.)
RE: Battery life: Maybe really a hardware issue? - by Zebulon Walton - 09-08-2021, 07:42 AM
  rough estimate of expected microSD installation life? andrewp907 7 3,753 06-10-2023, 07:55 PM
  volume down button issue sapphire 0 441 05-20-2023, 06:25 AM
Last Post: sapphire
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,557 05-10-2023, 03:31 AM
Last Post: fxc
  Megi's Kernel and Battery Life biketool 3 2,215 01-09-2023, 11:33 PM
Last Post: Canyonless
  UI crashes after unplugging USB device, seen on multiple OSes; is my hardware broken? slondr 1 1,007 11-05-2022, 11:31 AM
Last Post: slondr
Bug Pinephone Pro LTE issue DoesOkay 4 2,246 09-08-2022, 05:06 AM
Last Post: DoesOkay
  PinePhone Pro battery life Barugon 17 15,935 07-29-2022, 09:23 AM
Last Post: prog-amateur
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,575 06-23-2022, 02:44 PM
Last Post: zer0sig
Sad How many other users recieved a phone with FAULTY HARDWARE? johnnykeys 16 13,361 06-22-2022, 01:05 PM
Last Post: zer0sig
  Unhappy with immature Hardware jojuma 1 1,538 04-18-2022, 01:18 PM
Last Post: zetabeta
