Battery life: Maybe really a hardware issue?
(09-07-2021, 12:17 PM)KNERD Wrote: Well, if I turn off the phone, and battery is still drained, then it does not sound like a software  issue to me since no software is running
(I tried replying here and it seemed to go into the bit bucket, trying again...)
There's definitely something draining it. I had a near fully-charged battery in my Pinephone but have not used it in about a week or so. I decided to check for updates, so switched the modem off and plugged in a charger. After the phone booted up the wifi was also inactive. Checking power status the battery was down to 0%!
So, I put in my spare, fully charged battery and the wifi came back. (Updates are now installing.) As you say, it's not software because the OS isn't even running, but something is draining the battery when the phone is off. It appears that those of us who only use their phones occasionally need to leave the battery out until actually using it. Kind of a PITA. I'm surprised I haven't noticed this before but this is probably the longest that I had not even hooked a charger up to the phone.
RE: Battery life: Maybe really a hardware issue? - by Zebulon Walton - 09-07-2021, 05:59 PM
  rough estimate of expected microSD installation life? andrewp907 7 3,675 06-10-2023, 07:55 PM
  volume down button issue sapphire 0 432 05-20-2023, 06:25 AM
Last Post: sapphire
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,508 05-10-2023, 03:31 AM
Last Post: fxc
  Megi's Kernel and Battery Life biketool 3 2,178 01-09-2023, 11:33 PM
Last Post: Canyonless
  UI crashes after unplugging USB device, seen on multiple OSes; is my hardware broken? slondr 1 990 11-05-2022, 11:31 AM
Last Post: slondr
Bug Pinephone Pro LTE issue DoesOkay 4 2,201 09-08-2022, 05:06 AM
Last Post: DoesOkay
  PinePhone Pro battery life Barugon 17 15,768 07-29-2022, 09:23 AM
Last Post: prog-amateur
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,556 06-23-2022, 02:44 PM
Last Post: zer0sig
Sad How many other users recieved a phone with FAULTY HARDWARE? johnnykeys 16 13,190 06-22-2022, 01:05 PM
Last Post: zer0sig
  Unhappy with immature Hardware jojuma 1 1,516 04-18-2022, 01:18 PM
Last Post: zetabeta
