Mobian September 01, 2021
(09-01-2021, 04:15 AM)bcnaz Wrote: Just flashed a September 01 Nightly to an sd card,  running on a Pine Manjaro Convergent phone.
It did the normal disk 'resizing',     But there was no pop-up to help put the basic information into the phone.
  Now there is not a flashlight app on the desktop,  or in the onboard Software Store. ?
I did the "Updates" via   settings > about > update,  that went normally  using the wifi...
I attempted to use the cell/data after putting in my APN info, and turned on mobile data,  both Epiphany and Firefox would not load.
Then turned wifi back on,  Epiphany loaded...  turned wifi off again,  mobile data back on,    this time Epiphany loaded via cell/data.
Calls work both directions,  while the other person can hear me clearly, and they sound clear to me,  but I sound distorted to myself on the ear piece.
The text works, both in and out.  ...
AND  in the Power App,  with wifi off,  data off  just the modem on,
    While running on the battery,     it is showing between 2.0 and 2.2 watts of discharge. !
That is getting the power consumption down,  a bit lower with each release.
For what it's worth, the flashlight should be working from the drop down menu (or notification menu whatever it's called). Also, if you go to Mobile settings (inside of your Settings) and change Network Mode to 3G, 4G (Preferred) it really helps the call audio. I've also found that after setting my APN it took a bit of time before it properly connected but has been working fine for about 2 months or so.
Mobian September 01, 2021 - by bcnaz - 09-01-2021, 04:15 AM
RE: Mobian September 01, 2021 - by ragreenburg - 09-01-2021, 09:40 AM
RE: Mobian September 01, 2021 - by bcnaz - 09-01-2021, 11:45 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 24 2,375 4 hours ago
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,934 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 150 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,054 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,863 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 648 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,029 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,933 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 646 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,077 06-19-2023, 03:02 PM
Last Post: vusra
