low brightness in KDE makes screen unusably dark
(08-08-2021, 02:32 PM)mouffa Wrote: if the modem is powered off then setting the brightness to the minimum doesn't turn off the light but if the modem is on then the power is not enough and the light turns off, don't set it to the minimum if the modem is on
Good to know that. It still would be a good idea to make the minimum settable value a bit higher just that you can't accidentally render your phone unusable that easy.
RE: low brightness in KDE makes screen unusably dark - by cybercow - 08-09-2021, 10:53 AM
  screen brightness Uturn 1 1,783 10-09-2023, 04:38 AM
Last Post: Eugo
  screen brightness locked Uturn 0 1,325 07-07-2023, 09:38 AM
Last Post: Uturn
  Backup and Home Screen Tinkering on Phosh jakfish 0 1,404 02-24-2023, 12:56 PM
Last Post: jakfish
  Screen timeout makes alarm and timer unusable... Eugo 9 7,285 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 3,276 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 10,236 09-05-2022, 03:50 PM
Last Post: christev1
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 1,608 07-04-2022, 11:42 AM
Last Post: tuxmain
  How to return to "home screen" hiddenpotato 7 9,066 03-05-2022, 06:21 AM
Last Post: dcinoz
  Manjaro Welcome screen landscape JohanB89 2 3,249 11-12-2021, 01:13 AM
Last Post: acrux
  KDE Plasma Mobile screen scaling Uturn 1 2,648 10-29-2021, 06:59 AM
Last Post: Uturn
