Very slow download speeds?
(07-12-2021, 12:48 PM)moonwalkers Wrote:
(07-11-2021, 11:36 AM)intervalz Wrote: Thanks so much for your reply. I installed the firmware from the first link you attached... but I'm having an issue with the second link. I tried executing the binary file in the brcm folder and got "Exec format error". I also received the same error on the rockchip folder's bin file. Please forgive my ignorance, but am I doing this wrong? (I'm trying this on Manjaro ARM).
You're not supposed to execute those binaries directly, you're supposed to copy them into a specific location in your file system, and then if you did that correctly they will be loaded automatically when the device driver modules initialize. Check https://github.com/daniel-thompson/pineb...#L234-L235 for details - specifically, you should be copying them files into /lib/firmware/brcm/
Thanks so much for your help! I'm going to give that a shot.
Very slow download speeds? - by intervalz - 07-10-2021, 01:16 PM
RE: Very slow download speeds? - by moonwalkers - 07-10-2021, 07:25 PM
RE: Very slow download speeds? - by intervalz - 07-11-2021, 11:36 AM
RE: Very slow download speeds? - by moonwalkers - 07-12-2021, 12:48 PM
RE: Very slow download speeds? - by intervalz - 07-12-2021, 01:05 PM
RE: Very slow download speeds? - by wdt - 07-12-2021, 06:17 PM
RE: Very slow download speeds? - by intervalz - 07-12-2021, 06:50 PM
RE: Very slow download speeds? - by hbargerson - 12-18-2022, 11:38 PM
RE: Very slow download speeds? - by gulshan212 - 02-09-2023, 11:51 PM
  multilib.db failed to download Paulperry3 1 2,579 08-17-2021, 04:51 AM
Last Post: jiyong
  Chromium Dino game is slow/glitchy stozi 0 1,354 04-21-2021, 08:18 AM
Last Post: stozi
  Wifi very slow on PBP Manjaro? WeaseleyRon 2 3,051 01-21-2021, 10:21 AM
Last Post: moonwalkers
  Wifi very slow on PBP Manjaro motezart 3 4,056 10-13-2020, 07:30 PM
