Device unable to boot
Thanks for the insight LMM,
With all the boot tries and reflashing I did, I don't expect to have inserted the SD card every single time.
When it comes to the power supply I'm using one of the recommended power supplied. It's a 12v@3A power supply.
I'm trying to boot the device without any accessory attached, so I don't think I'm actually overloading the power supply.
And I've followed the exact same tutorial to try to establish a serial connection.
I've been using the 1.5MBaud rate,
I was connecting the RX lead to the pin 8 and used the ground lead on pin 6 while keeping the TX lead disconnected to make sure I don't impede the boot process.
The serial adapter was set at 3.3v
I haven't tried to flash the SPI with UBoot yet since currently I'm waiting for the Pine support to issue a RMA so I can test if I just received a lemon.
But I still tried to see if I would get anything out of serial connection even without any SD card, and I just get the same goop as when the SD card is in.
And the emmc isn't an option since I didn't buy any emmc modules and prefer to run directly from a SD card for the time being for simplicity.
Device unable to boot - by Lunix33 - 06-15-2021, 09:51 PM
RE: Device unable to boot - by LMM - 06-20-2021, 03:18 AM
RE: Device unable to boot - by Lunix33 - 06-22-2021, 07:51 AM
RE: Device unable to boot - by LMM - 06-22-2021, 11:58 AM
RE: Device unable to boot - by LMM - 06-22-2021, 01:09 PM
RE: Device unable to boot - by Lunix33 - 06-22-2021, 08:17 PM
RE: Device unable to boot - by Lunix33 - 07-04-2021, 06:00 PM
RE: Device unable to boot - by t4_4t - 07-05-2021, 08:25 PM
RE: Device unable to boot - by Lunix33 - 09-22-2021, 10:31 AM
RE: Device unable to boot - by LMM - 09-23-2021, 01:38 AM
  enble boot after power loss/restore dkebler 18 9,451 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 119,680 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 671 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,262 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,331 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,554 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,219 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,153 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,806 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,166 06-09-2022, 10:56 AM
Last Post: pspgarret
