How do you install VPN so you can set up a config file, tor, signal and disk encrypt?
I am running Tor on my PinePhone, setup works just like it would work on desktop Linux. Regarding VPNs, if they use standard protocols like Wireguard or OpenVPN, you won't even need an app.
Signal is a bit difficult, I am using Axolotl, and it's ok for texting. For more read the Mobian Wiki.
I suggest you to check out the video channels of RTP, he made many videos about these topics and the PinePhone: Odysee (https://odysee.com/@RTP:9), YouTube.
RE: How do you install VPN so you can set up a config file, tor, signal and disk encrypt? - by linmob - 05-26-2021, 04:07 PM
  Can't install Manjaro thorensjubilee 1 1,038 02-09-2023, 08:17 AM
Last Post: thorensjubilee
  Axolotl signal client package lolgzs 27 19,757 11-02-2022, 04:55 AM
Last Post: shulamy
  No keyboard in Signal Desktop Kimberley van Buyten 4 2,412 10-16-2022, 10:25 AM
Last Post: Eugo
  How to install iptables extensions? I get "Extension owner revision 0 not supported" anon4 0 2,157 08-27-2022, 12:19 PM
Last Post: anon4
  Can't install software via Discover or Terminal Kimberley van Buyten 2 1,573 06-10-2022, 02:13 AM
Last Post: shulamy
  Chatty -- no response after install tckosvic 0 1,118 12-11-2021, 09:55 AM
Last Post: tckosvic
  After fresh install outbound phone calls not working. tckosvic 2 2,378 11-10-2021, 10:45 AM
Last Post: tckosvic
  Crash when Updating Manjaro-Plasma. Hanging on "checking available disk space" UN_Owen 0 1,119 06-27-2021, 01:38 PM
Last Post: UN_Owen
  Can i install 16 different distros apart from the default manjaro? temp0rary 4 3,942 05-28-2021, 03:55 PM
Last Post: temp0rary
  file transfer Rainer 3 3,044 05-10-2021, 08:53 PM
Last Post: Rainer
