PWM whine near earpiece in low signal phone call and loud sound sent to the other end
#29
I've opened the phone (mine is Mobian Edition 2/16GB) and did some experiments confirming that the modem antenna system is interfering with the microphone when the modem does work.
When I disconnected the antenna black cable the modem had no network signal. But I've successfully use the Wifi antenna cable from my laptop (had to opened it too) that I've connected to ANT_MAIN near the modem ( c2 as used here:  https://forum.pine64.org/showthread.php?tid=15474 ).
So with the modem getting the signal using my laptop's Wifi antenna (instead of the phone's bottom antenna), the microphone worked great -- no "digital" noise whatsoever (voice calls or mobile data usage).
It doesn't seem to me to be an easy solution to fix this. There are some possibilities that I'm imaging:
- Pine64 to come up with another USB-C board and/or the plastic frame with printed antennas that doesn't affect the microphone.
- me to make a custom antenna and place it maybe between the battery and the back cover or on the side ...
- don't know... any ideas?
Until then, I'll continue to use the mic without boost (level at 0). The noises are gone, but the sound volume is very low and some people struggle hearing me.... Recording sounds is pretty useless like this too.
RE: PWM whine near earpiece in low signal phone call and loud sound sent to the other end - by eugenr - 01-07-2022, 11:19 AM
  Phone powers off with high user demands car46999 7 592 04-11-2024, 09:17 AM
Last Post: zetabeta
  Phone will not turn on (but sometimes will) insidetrip101 10 4,775 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 1,066 07-31-2023, 07:50 PM
  No calls on Pine Phone Beta convergence edition polypode 1 1,174 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 1,130 02-20-2023, 12:14 AM
  I cannot call or receive calls aka0kuro 6 3,077 01-13-2023, 05:31 PM
Last Post: alaraajavamma
Thumbs Down Phone is unresponsive theneedful 14 7,642 08-12-2022, 08:18 AM
Last Post: theneedful
  Phone Dead Already? MarsColonist 4 2,690 08-11-2022, 11:52 AM
Last Post: auanta
  PPKB with phone; phone dies while charging SwordfishII 1 1,374 06-08-2022, 04:14 AM
Last Post: SwordfishII
  Lost internal earpiece Veraendert 3 2,378 02-14-2022, 07:51 AM
Last Post: Veraendert
