xmpp&jabber client for Manjaro Plasma mobile
(03-24-2021, 02:07 AM)acrux Wrote: So - what is the best option to have up-to-date (MUC, MAM etc) jabber&xmpp chat in Plasma mobile?
  • Manjaro Phosh has Chatty. It supports message archive managment (MAM), message carbons etc and is good for private conversations. Drawbacks - no multi user chat (MUC) and it pulls in quite much Gnome packages as dependencies. As in Phosh it is used also as a SMS client, it could interfere with Plasma Spacebar app.
  • SailfishOS also integrates SMS app with xmpp one using telepathy-gabble. There is telepathy-gabble-plus update (http://devel.kondorgulasch.de/telepathy-gabble/) which extends it with MAM etc. Maybe a similar method could be possible to add xmpp to the Spacebar app? However - still no MUC
  • Gajim. Probably the best jabber client for Linux (with Dino). Sort of usable in Plasma mobile if the window sizes and other options are optimized in conf file. Roster and personal chats are scaled ok and keyboard integrates quite ok also. Needs double-tap to open chats in roster. MUC windows are not scaled correctly and keyboard hides the input field.
  • Dino. Probably the best jabber client for Linux (with Gajim). However, the current Dino for Manjaro&Plasma is the desktop one and although it starts and runs, it does not scale correctly and I was unable to input text as the keyboard did not pop up. However - there is a project to use libhandy for Dino to adapt it to mobile screens (https://github.com/dino/dino/issues/178) and the result is already promising (https://fosstodon.org/@linmob/105583488991640393). Any chance to get this branch into Manjaro&Plasma?
Swift
RE: xmpp&jabber client for Manjaro Plasma mobile - by Veraendert - 03-26-2021, 04:03 AM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,614 10-02-2023, 05:07 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 590 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,513 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,605 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 809 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,764 03-02-2023, 07:25 PM
  gnome-mobile dev Uturn 1 1,117 02-22-2023, 03:37 AM
Last Post: acrux
  Can't install Manjaro thorensjubilee 1 1,030 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 4,914 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,584 11-22-2022, 05:00 PM
Last Post: Chief
