Installing Mobian --> "Resizing file system" forever
(08-31-2021, 11:59 PM)bcnaz Wrote: If you are using Balena Etcher :
      You do not SUDO  anything.
Thanks! Sorry if I did not express myself clearly: I had tried "sudo zcat..." and, after that attempt failed, I tried Balena Etcher, both several times.
The solution was @dukla2000 's answer.
RE: Installing Mobian --> "Resizing file system" forever - by Anna - 09-01-2021, 03:52 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 17 2,080 8 hours ago
Last Post: diederik
  Mobian repository status henrythemouse 16 8,793 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 134 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,012 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Errors when start the system kubussz 2 567 11-21-2023, 11:07 AM
Last Post: kubussz
  System won't suspend due to suspention notification user641 6 1,424 09-24-2023, 05:47 AM
Last Post: user641
  What actions needed to keep on mobian testing user641 3 1,833 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 636 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,929 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,906 07-09-2023, 01:37 AM
Last Post: vusra
