Serious hinge crapout
OK, I read some more posts.  It's out of warranty so I don't need to baby it anymore.  Sounds like a rod going through a split sleeve, so prying the sleeve open a little more is probably good.  I wonder how it would be to smear the rod with a light coating of good quality automotive grease, maybe I've got some silicone.
I carried a laptop bag with various laptops in it for 15 years or so but I'm retired now.  If you use it in your lap you end up putting it down a lot so I closed it a lot.  Set the config file line to ignore lid close and I was off and running.  Before that I found that standing it up on one side but leaving it open works fairly well.  I don't take it many places but because of the long battery life I used it a lot for doing nature recordings with a USB sound card and experimental microphones and preamps.
Buying another USB adapter for the nvme, well, I wanted another anyway.  The speed of the SSD makes up for the slowness of the USB connection so they're quite handy to plug into various Linux boxes.  I have a 2 TB one plugged into an old Raspberry Pi downstairs.  180 year MTBF is hard to beat, Intel makes that claim on theirs.
Serious hinge crapout - by ab1jx - 03-09-2021, 10:18 AM
RE: Serious hinge crapout - by vfr400racer - 03-09-2021, 01:33 PM
RE: Serious hinge crapout - by ab1jx - 03-09-2021, 03:29 PM
RE: Serious hinge crapout - by moonwalkers - 03-09-2021, 06:19 PM
RE: Serious hinge crapout - by ab1jx - 03-09-2021, 08:20 PM
RE: Serious hinge crapout - by accassar - 04-04-2021, 03:41 PM
RE: Serious hinge crapout - by ab1jx - 04-04-2021, 05:23 PM
RE: Serious hinge crapout - by ab1jx - 10-06-2021, 03:05 PM
  Pinebook Pro sleep issue (hinge?) pciman 1 2,885 07-12-2020, 12:48 AM
Last Post: MtnSk8
  Hinge Clicking Noise on Closing and Opening SamWilts 5 6,288 05-28-2020, 04:26 PM
Last Post: SamWilts
