Fail safe way to update ANX7688 firmware
(02-28-2021, 10:03 AM)MtnSk8 Wrote: Hi, is the serial cable the only way into the pmos test image? I booted it, and it loaded the test utility and the automatic test bricked my modem after hanging on the "Upgrading EG25" (no idea why it was not just a "test" like the button I clicked suggested Smile .  Anyway my modem is not detected by any os and I don't have a serial cable. OP says "easiest way" but is it the only way? can I use a keyboard?
Thanks.
Hi MtnSk8,
i'm sorry but i can't help you out on this issue.
I guess you'll have to find out, how the pmos test images are build and how to add some kind of console access... maybe using USB cable.
I choosed this image, because it was just enough to start with and it is a fixed environment.
Though the serial cable is little bit special it just works (BTW, you'll have to switch of headphones with the kill switch).
For the bricked modem, it may help to find what the test initates when pressing the button.
Hopefully you're able to revive the modem part.
Regards,
scholbert
RE: Fail safe way to update ANX7688 firmware - by scholbert - 03-01-2021, 08:07 AM
  firmware udate Quectel EG25-G modem alwi 7 5,486 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 2,921 07-06-2022, 12:35 PM
  camera firmware problems kqlnut 25 21,897 09-02-2021, 07:49 PM
  3/32 upgrade board, Arrived Without Firmware, Troubleshooting Steps to SOLVED biketool 0 1,743 06-22-2021, 10:03 AM
  WIFI not available after anx7688 update failure frimmel 21 19,691 05-11-2021, 02:45 AM
Last Post: frimmel
  Pinephone mainboard v1.2 documentation update? scholbert 1 2,690 01-18-2021, 09:01 PM
Last Post: bokomaru
  New motherboard - ANX firmware won't flash. --- 17 13,381 12-26-2020, 01:53 PM
Last Post: p1x3l3d
  Update to 3GB/32GB mainboard not working tlo 2 3,748 11-09-2020, 04:40 PM
Last Post: tlo
  BraveHeart UbPorts Battery drain/Solder update Vlodka 2 3,545 10-04-2020, 11:18 PM
Last Post: Vlodka
