Pogo pins power clarification - reading schematics
#20
I'll need some time to go through your response in detail. Smile
In the meantime, please have a look at the PineEye schematic, which uses the pogo pins.  It simply takes power from both USB-5V and DCIN pogo pins, again with no isolation (yikes!), and uses a separate 3.3 V regulator.
Obviously, PineEye uses 3.3 V for its power supply voltage, which requires it to use a separate buck regulator.  However, some other "pogo mod" requiring 5 V as the power supply voltage would also have to use a separate buck/boost 5 V regulator, which IMHO raises some questions about the phone design.
RE: Pogo pins power clarification - reading schematics - by dsimic - 02-14-2021, 03:29 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 547 02-17-2024, 04:15 PM
Last Post: vortex
  Pinephone - broken power button rorus 10 9,265 05-18-2023, 09:11 AM
Last Post: kbm
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,535 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 4,666 06-22-2022, 06:04 PM
Last Post: albafrati
  pine64 keyboard pogo 'no-go' pins --- 3 2,531 04-29-2022, 04:59 AM
Last Post: Humid Stylus
  what are these pins above modem chip? zetabeta 1 1,615 12-13-2021, 04:38 AM
Last Post: kqlnut
  Power consumption during the call some_pinephone_user 0 1,152 10-29-2021, 06:03 AM
Last Post: some_pinephone_user
  on off power button stopped working dcinoz 3 2,577 09-01-2021, 03:26 AM
Last Post: dcinoz
  Won't boot until connected to power after sudden power loss brb78 1 1,734 08-30-2021, 12:41 AM
Last Post: bcnaz
  Regarding USB Power and Modem Initialization vidual 2 2,736 08-26-2021, 11:48 PM
Last Post: vidual
