Needed basic Info on using Webcam on PBP
(12-15-2020, 12:13 PM)Arwen Wrote: First check to see if the web camera is seen by the OS. I'd normally use "lsusb".
If it is not seen by the OS, then it's probably the privacy switch. I didn't remember which one that is, but checking the Wiki;
Wiki - Pinebook Pro - Privacy Switches
Let us know the results.
I ran the lsusb and no joy on webcam, reviewed and implemented the privacy switches in the Wiki.  Then the lsusb shows the webcam, progress there.  Restarted PBP.
Went to Applications and started Cheese.  No errors noted, however, no picture available either.  Removed Cheese, Restarted.  Installed Cheese from Flatpak, previous was from Official Repositories.  Restarted.
That worked !
Thank you, thank you, thank you.
Ed
RE: Needed basic Info on using Webcam on PBP - by User 17828 - 12-15-2020, 01:59 PM
Sad Webcam not working in pinebook pro with Manjaro jcarball 2 3,181 04-28-2021, 03:23 PM
Last Post: jcarball
  Built-in Webcam Not Working fozzedout 36 42,215 02-01-2021, 08:59 AM
Last Post: lemaurien19
  webcam photo solid gray stozi 0 1,555 01-05-2021, 05:35 PM
Last Post: stozi
