Remove striped screw
Desperate ?
  Perhaps use a heavy round tooth pick,  cut it in the middle to give a good surface area.
Use a small drop of super glue to secure the blunt end of the tooth pick to the head of the screw.
Allow plenty of time for the glue to "set-up"...  + ( the glue will dry fast on the tooth pick, but will take longer to dry on the metal screw )
Very carefully turn counter-clockwise and gently lift the screw.
Hope that helps
Remove striped screw - by pizzalovingnerd - 11-21-2020, 08:20 PM
RE: Remove striped screw - by bcnaz - 11-21-2020, 08:53 PM
RE: Remove striped screw - by pizzalovingnerd - 11-21-2020, 11:09 PM
RE: Remove striped screw - by bcnaz - 11-21-2020, 11:16 PM
RE: Remove striped screw - by pizzalovingnerd - 11-22-2020, 01:13 AM
RE: Remove striped screw - by bcnaz - 11-22-2020, 01:51 AM
RE: Remove striped screw - by pizzalovingnerd - 11-22-2020, 09:11 PM
RE: Remove striped screw - by User 18618 - 11-22-2020, 04:25 PM
RE: Remove striped screw - by KC9UDX - 11-22-2020, 07:48 PM
RE: Remove striped screw - by hiimtye - 11-22-2020, 09:36 PM
RE: Remove striped screw - by pizzalovingnerd - 11-23-2020, 11:14 AM
RE: Remove striped screw - by LazLong - 11-22-2020, 10:15 PM
RE: Remove striped screw - by hiimtye - 11-22-2020, 11:12 PM
RE: Remove striped screw - by bcnaz - 11-25-2020, 06:49 PM
RE: Remove striped screw - by RTP - 11-25-2020, 11:26 PM
RE: Remove striped screw - by bcnaz - 11-30-2020, 06:37 PM
RE: Remove striped screw - by hiimtye - 11-30-2020, 09:14 PM
RE: Remove striped screw - by dsimic - 12-06-2020, 09:31 AM
RE: Remove striped screw - by tllim - 12-08-2020, 02:22 PM
  DIY case backs, screw attachment biketool 1 2,000 04-07-2021, 10:07 AM
Last Post: wibble
  NO AFTER SALE SUPPORT --> After one week no way to remove batterie harvey186 19 19,979 05-17-2020, 02:01 PM
Last Post: 33YN2
