(11-12-2020, 07:27 PM)megous Wrote:(11-12-2020, 01:15 AM)aithal Wrote: I have been using Pinephone UBports edition since August. I have been trying out different OS versions, but always had a stable customized SXMO build of PMOS which I have been using with all basic phone functionalities working.
When I upgraded to kernel 5.9.1 pmos sxmo on another sdcard, the wifi and bluetooth stopped working.
The demsg log is as follows -
Code:[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.9.1 (pmos@build)
(aarch64-alpine-linux-musl-gcc (Alpine 10.2.0) 10.2.0, GNU ld (GNU
Binutils) 2.35.1) #4-postmarketos-allwinner SMP Fri Oct 30 07:37:12 UTC
2020
[ 0.000000] Machine model: Pine64 PinePhone (1.2)
[ 0.000000] earlycon: uart0 at MMIO32 0x0000000001c28000 (options '')
[ 0.000000] printk: bootconsole [uart0] enabled
[ 0.000000] cma: Reserved 256 MiB at 0x00000000b0000000
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xafbcc100-0xafbcdfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] DMA32 [mem 0x0000000080000000-0x00000000bfffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
[ 0.000000] On node 0 totalpages: 524288
[ 0.000000] DMA zone: 4096 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 262144 pages, LIFO batch:63
[ 0.000000] DMA32 zone: 4096 pages used for memmap
[ 0.000000] DMA32 zone: 262144 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112
[ 0.000000] pcpu-alloc: s50008 r8192 d31912 u90112 alloc=22*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] CPU features: detected: ARM erratum 843419
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: init=/init.sh rw console=tty0
console=ttyS0,115200 earlycon=uart,mmio32,0x01c28000 panic=10
consoleblank=0 loglevel=1 cma=256M PMOS_NO_OUTPUT_REDIRECT
PMOS_FORCE_PARTITION_RESIZE pmos_boot=/dev/mmcblk0p1
pmos_root=/dev/mmcblk0p2
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x7bfff000-0x7ffff000] (64MB)
[ 0.000000] Memory: 1709188K/2097152K available (10942K kernel code,
650K rwdata, 4064K rodata, 1792K init, 388K bss, 125820K reserved,
262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x304/0x4cc with crng_init=0
[ 0.000000] arch_timer: Enabling global workaround for Allwinner erratum UNKNOWN1
[ 0.000000] arch_timer: CPU0: Trapping CNTVCT access
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000456] Console: colour dummy device 80x25
[ 0.000470] printk: console [tty0] enabled
[ 0.000562] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.000571] pid_max: default: 32768 minimum: 301
[ 0.000662] LSM: Security Framework initializing
[ 0.000739] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.000759] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.002520] rcu: Hierarchical SRCU implementation.
[ 0.003148] smp: Bringing up secondary CPUs ...
[ 0.004663] Detected VIPT I-cache on CPU1
[ 0.004726] arch_timer: CPU1: Trapping CNTVCT access
[ 0.004739] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005705] Detected VIPT I-cache on CPU2
[ 0.005736] arch_timer: CPU2: Trapping CNTVCT access
[ 0.005744] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.006604] Detected VIPT I-cache on CPU3
[ 0.006631] arch_timer: CPU3: Trapping CNTVCT access
[ 0.006639] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.006711] smp: Brought up 1 node, 4 CPUs
[ 0.006716] SMP: Total of 4 processors activated.
[ 0.006721] CPU features: detected: 32-bit EL0 Support
[ 0.006727] CPU features: detected: CRC32 instructions
[ 0.020620] CPU: All CPU(s) started at EL2
[ 0.020645] alternatives: patching kernel code
[ 0.022461] devtmpfs: initialized
[ 0.030904] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.030929] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.040529] pinctrl core: initialized pinctrl subsystem
[ 0.041918] NET: Registered protocol family 16
[ 0.043680] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.043744] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.043895] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.044861] thermal_sys: Registered thermal governor 'fair_share'
[ 0.044866] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.044873] thermal_sys: Registered thermal governor 'step_wise'
[ 0.044876] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.045640] cpuidle: using governor menu
[ 0.045820] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.045931] ASID allocator initialised with 65536 entries
[ 0.046089] Serial: AMBA PL011 UART driver
[ 0.085528] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.085541] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.085546] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.085551] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.087105] cryptd: max_cpu_qlen set to 1000
[ 0.091407] iommu: Default domain type: Translated
[ 0.091798] SCSI subsystem initialized
[ 0.092148] usbcore: registered new interface driver usbfs
[ 0.092209] usbcore: registered new interface driver hub
[ 0.092301] usbcore: registered new device driver usb
[ 0.093398] mc: Linux media interface: v0.10
[ 0.093453] videodev: Linux video capture interface: v2.00
[ 0.093775] EDAC MC: Ver: 3.0.0
[ 0.095923] clocksource: Switched to clocksource arch_sys_counter
[ 0.096177] VFS: Disk quotas dquot_6.6.0
[ 0.096241] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.108042] NET: Registered protocol family 2
[ 0.108527] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.108566] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.108723] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.109058] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.109195] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.109254] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.109435] NET: Registered protocol family 1
[ 0.110008] RPC: Registered named UNIX socket transport module.
[ 0.110012] RPC: Registered udp transport module.
[ 0.110015] RPC: Registered tcp transport module.
[ 0.110017] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.110718] Unpacking initramfs...
[ 0.183151] Freeing initrd memory: 1420K
[ 0.184109] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.188579] Initialise system trusted keyrings
[ 0.188775] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[ 0.197396] NFS: Registering the id_resolver key type
[ 0.197430] Key type id_resolver registered
[ 0.197433] Key type id_legacy registered
[ 0.197537] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.197753] fuse: init (API version 7.31)
[ 0.251203] Key type asymmetric registered
[ 0.251211] Asymmetric key parser 'x509' registered
[ 0.251269] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.251276] io scheduler mq-deadline registered
[ 0.251280] io scheduler kyber registered
[ 0.257685] sun50i-a64-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[ 0.259080] sun50i-a64-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
[ 0.279288] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.292047] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
[ 0.292096] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
[ 0.292145] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
[ 0.292189] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
[ 0.292580] lima 1c40000.gpu: bus rate = 200000000
[ 0.292587] lima 1c40000.gpu: mod rate = 432000000
[ 0.293008] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 0
[ 0.303316] loop: module loaded
[ 0.303855] zram: Added device: zram0
[ 0.305862] libphy: Fixed MDIO Bus: probed
[ 0.305874] tun: Universal TUN/TAP device driver, 1.6
[ 0.306227] VFIO - User Level meta-driver version: 0.3
[ 0.307681] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.307689] ehci-platform: EHCI generic platform driver
[ 0.308176] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.308207] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.308345] ehci-platform 1c1a000.usb: irq 20, io mem 0x01c1a000
[ 0.323967] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.324794] hub 1-0:1.0: USB hub found
[ 0.324838] hub 1-0:1.0: 1 port detected
[ 0.325795] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.325834] ohci-platform: OHCI generic platform driver
[ 0.326074] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.326095] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.326228] ohci-platform 1c1a400.usb: irq 21, io mem 0x01c1a400
[ 0.388681] hub 2-0:1.0: USB hub found
[ 0.388723] hub 2-0:1.0: 1 port detected
[ 0.390244] usbcore: registered new interface driver usb-storage
[ 0.393794] sun6i-rtc 1f00000.rtc: registered as rtc0
[ 0.393850] sun6i-rtc 1f00000.rtc: setting system clock to 2020-11-09T05:55:36 UTC (1604901336)
[ 0.393857] sun6i-rtc 1f00000.rtc: RTC enabled
[ 0.394058] i2c /dev entries driver
[ 0.395756] sun8i-di 1e00000.deinterlace: Device registered as /dev/video0
[ 0.398611] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[ 0.399324] sdhci: Secure Digital Host Controller Interface driver
[ 0.399330] sdhci: Copyright(c) Pierre Ossman
[ 0.399472] Synopsys Designware Multimedia Card Interface Driver
[ 0.400619] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.402005] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.402520] SMCCC: SOC_ID: ARCH_FEATURES(ARCH_SOC_ID) returned error: fffffffffffffffd
[ 0.402600] hid: raw HID events driver (C) Jiri Kosina
[ 0.403622] usbcore: registered new interface driver usbhid
[ 0.403632] usbhid: USB HID core driver
[ 0.405495] cedrus 1c0e000.video-codec: Device registered as /dev/video1
[ 0.406594] ashmem: initialized
[ 0.412375] NET: Registered protocol family 17
[ 0.412475] Key type dns_resolver registered
[ 0.412912] registered taskstats version 1
[ 0.412920] Loading compiled-in X.509 certificates
[ 0.430671] sun8i-rotate 1020000.rotate: Device registered as /dev/video2
[ 0.435658] sunxi-rsb 1f03400.rsb: RSB running at 4000000 Hz
[ 0.436139] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP803 found
[ 0.438190] input: axp20x-pek as /devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input0
[ 0.443672] axp20x-adc axp813-adc: DMA mask not set
[ 0.446286] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
[ 0.452103] axp20x-battery-power-supply axp20x-battery-power-supply: Configuring battery thermal regulation for Pinephone
[ 0.454529] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set
[ 0.455956] random: fast init done
[ 0.456743] dcdc1: supplied by regulator-dummy
[ 0.457198] dcdc2: supplied by regulator-dummy
[ 0.457478] dcdc4: supplied by regulator-dummy
[ 0.457755] dcdc5: supplied by regulator-dummy
[ 0.458062] dcdc6: supplied by regulator-dummy
[ 0.458329] dc1sw: supplied by regulator-dummy
[ 0.458552] aldo1: supplied by regulator-dummy
[ 0.458626] dovdd-csi: Bringing 3300000uV into 1800000-1800000uV
[ 0.458929] aldo2: supplied by regulator-dummy
[ 0.459192] aldo3: supplied by regulator-dummy
[ 0.459467] dldo1: supplied by regulator-dummy
[ 0.459770] dldo2: supplied by regulator-dummy
[ 0.460184] dldo3: supplied by regulator-dummy
[ 0.460623] dldo4: supplied by regulator-dummy
[ 0.460709] vcc-wifi-io: Bringing 3300000uV into 1800000-1800000uV
[ 0.461052] eldo1: supplied by regulator-dummy
[ 0.461349] eldo2: supplied by regulator-dummy
[ 0.461642] eldo3: supplied by regulator-dummy
[ 0.461713] dvdd-1v8-csi: Bringing 700000uV into 1800000-1800000uV
[ 0.461995] fldo1: supplied by regulator-dummy
[ 0.462291] fldo2: supplied by regulator-dummy
[ 0.462589] rtc-ldo: supplied by regulator-dummy
[ 0.462868] ldo-io0: supplied by regulator-dummy
[ 0.463161] ldo-io1: supplied by regulator-dummy
[ 0.463229] vcc-1v8-typec: Bringing 3300000uV into 1800000-1800000uV
[ 0.463541] axp20x-rsb sunxi-rsb-3a3: AXP20X driver loaded
[ 0.469458] sun50i-a64-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.472047] printk: console [ttyS0] disabled
[ 0.472144] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 32, base_baud = 1500000) is a 16550A
[ 0.472197] printk: console [ttyS0] enabled
[ 0.472201] printk: bootconsole [uart0] disabled
[ 0.473972] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 33, base_baud = 1500000) is a 16550A
[ 0.474189] serial serial0: tty port ttyS1 registered
[ 0.475337] 1c28c00.serial: ttyS2 at MMIO 0x1c28c00 (irq = 34, base_baud = 1500000) is a 16550A
[ 0.475519] serial serial1: tty port ttyS2 registered
[ 0.481196] modem-power serial1-0: modem power manager ready
[ 0.507412] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_ops)
[ 0.509266] sun4i-drm display-engine: bound 1200000.mixer (ops sun8i_mixer_ops)
[ 0.509793] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[ 0.509812] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_ops)
[ 0.510036] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops sun4i_tcon_ops)
[ 0.510071] sun4i-drm display-engine: bound 1ca0000.dsi (ops sun6i_dsi_ops)
[ 0.511413] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[ 0.512092] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.512593] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops)
[ 0.513357] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 1
[ 0.513459] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[ 0.514580] ehci-platform 1c1b000.usb: EHCI Host Controller
[ 0.514605] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[ 0.514747] ehci-platform 1c1b000.usb: irq 22, io mem 0x01c1b000
[ 0.514869] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[ 0.527975] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[ 0.528781] hub 3-0:1.0: USB hub found
[ 0.528821] hub 3-0:1.0: 1 port detected
[ 0.530117] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[ 0.530142] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
[ 0.530300] ohci-platform 1c1b400.usb: irq 23, io mem 0x01c1b400
[ 0.592783] hub 4-0:1.0: USB hub found
[ 0.592826] hub 4-0:1.0: 1 port detected
[ 0.594175] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
[ 0.595241] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
[ 0.595268] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
[ 0.595374] phy id_det change to device
[ 0.596106] hub 5-0:1.0: USB hub found
[ 0.596145] hub 5-0:1.0: 1 port detected
[ 0.701413] Goodix-TS 1-005d: ID 917S, version: 0200
[ 0.704980] Goodix-TS 1-005d: Direct firmware load for goodix_917S_cfg.bin failed with error -2
[ 0.709406] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pe not found, using dummy regulator
[ 0.717453] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[ 0.720320] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 0.724934] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 0.727984] input: Goodix Capacitive TouchScreen as /devices/platform/soc/1c2ac00.i2c/i2c-1/1-005d/input/input1
[ 0.729721] sunxi-mmc 1c11000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[ 0.732797] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
[ 0.785819] mmc0: new high speed SDHC card at address aaaa
[ 0.786660] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[ 0.789380] mmcblk0: p1 p2
[ 0.913181] mmc2: new DDR MMC card at address 0001
[ 0.914233] mmcblk2: mmc2:0001 14.7 GiB
[ 0.914722] mmcblk2boot0: mmc2:0001 partition 1 4.00 MiB
[ 0.915206] mmcblk2boot1: mmc2:0001 partition 2 4.00 MiB
[ 0.920124] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[ 0.942291] Console: switching to colour frame buffer device 90x90
[ 0.980374] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
[ 0.980397] sun6i-mipi-dsi 1ca0000.dsi: Attached device xbd599
[ 0.980431] panel-sitronix-st7703 1ca0000.dsi.0: [drm:st7703_probe] 720x1440@60 24bpp dsi 4dl - ready
[ 0.981594] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 0.983873] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 0.984439] dw-apb-uart 1c28000.serial: forbid DMA for kernel console
[ 0.985738] Freeing unused kernel memory: 1792K
[ 0.985924] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 0.985933] cfg80211: failed to load regulatory.db
[ 1.007999] Run /init as init process
[ 1.008002] with arguments:
[ 1.008004] /init
[ 1.008007] PMOS_NO_OUTPUT_REDIRECT
[ 1.008009] PMOS_FORCE_PARTITION_RESIZE
[ 1.008011] with environment:
[ 1.008013] HOME=/
[ 1.008016] TERM=linux
[ 1.008018] pmos_boot=/dev/mmcblk0p1
[ 1.008020] pmos_root=/dev/mmcblk0p2
[ 1.127928] anx7688 1-0028: power enabled
[ 1.128776] anx7688 1-0028: Vendor id 0x1f29
[ 1.143923] anx7688 1-0028: power disabled
[ 1.144226] anx7688 1-0028: plug irq (cd=1)
[ 1.144348] anx7688 1-0028: enabling USB BC 1.2 detection
[ 1.144396] anx7688 1-0028: setting vbus_in current limit to 500000 mA
[ 1.159945] anx7688 1-0028: cable inserted
[ 1.199936] anx7688 1-0028: power enabled
[ 1.265033] anx7688 1-0028: eeprom0 = 0x03
[ 1.265296] anx7688 1-0028: fw loaded after 40 ms
[ 1.266694] anx7688 1-0028: OCM firmware loaded (version 0x2312)
[ 1.277433] anx7688 1-0028: send pd packet cmd=0 05 00 32 90 01 26 12
[ 1.313159] anx7688 1-0028: send pd packet cmd=1 05 01 2c 91 01 26 16
[ 1.314837] anx7688 1-0028: send pd packet cmd=2 11 02 00 00 00 ec 00 00 00 00 00 00 00 00 39 00 00 51 77
[ 1.317613] anx7688 1-0028: send pd packet cmd=3 05 03 00 00 01 ff f8
[ 1.319286] anx7688 1-0028: OCM configuration completed
[ 1.320676] anx7688 1-0028: status changed to 0x00
[ 1.320687] anx7688 1-0028: cc_status changed to CC1 = SRC.Open CC2 = SRC.Open
[ 1.320692] anx7688 1-0028: dp state changed to 0x00
[ 1.412776] anx7688 1-0028: cc_status changed to CC1 = SRC.Ra CC2 = SRC.Ra
[ 1.615869] using random self ethernet address
[ 1.615878] using random host ethernet address
[ 1.626825] usb0: HOST MAC 5a:5b:2e:43:59:4c
[ 1.626868] usb0: MAC 0e:e7:54:d1:5f:33
[ 1.664731] EXT4-fs (mmcblk0p1): mounted filesystem without journal. Opts: (null)
[ 3.796147] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.828991] EXT4-fs (mmcblk0p1): warning: mounting unchecked fs, running e2fsck is recommended
[ 3.871792] EXT4-fs (mmcblk0p1): mounted filesystem without journal. Opts: (null)
[ 3.871849] ext4 filesystem being mounted at /sysroot/boot supports timestamps until 2038 (0x7fffffff)
[ 5.728846] device-mapper: table: 253:0: linear: Device lookup failed
[ 5.728856] device-mapper: ioctl: error adding target to table
[ 5.742333] device-mapper: table: 253:0: linear: Device lookup failed
[ 5.742342] device-mapper: ioctl: error adding target to table
[ 6.199117] udevd[2015]: starting version 3.2.9
[ 6.222950] random: udevd: uninitialized urandom read (16 bytes read)
[ 6.224202] random: udevd: uninitialized urandom read (16 bytes read)
[ 6.224257] random: udevd: uninitialized urandom read (16 bytes read)
[ 6.289950] udevd[2015]: starting eudev-3.2.9
[ 6.418497] i2c-gpio i2c-csi: using lines 141 (SDA) and 140 (SCL)
[ 6.601725] NET: Registered protocol family 10
[ 6.602809] Segment Routing with IPv6
[ 6.655172] input: 1c21800.lradc as /devices/platform/soc/1c21800.lradc/input/input2
[ 6.775401] input: gpio-vibrator as /devices/platform/vibrator/input/input3
[ 6.784933] bt-sco bt-sco-codec: ASoC: sink widget Capture overwritten
[ 6.784949] bt-sco bt-sco-codec: ASoC: source widget Playback overwritten
[ 6.785058] simple-amplifier audio-amplifier: supply VCC not found, using dummy regulator
[ 6.789852] debugfs: File 'Playback' in directory 'dapm' already present!
[ 6.789867] debugfs: File 'Capture' in directory 'dapm' already present!
[ 6.792114] input: PinePhone Headset Jack as /devices/platform/sound/sound/card0/input4
[ 6.816748] iio iio:device3: interrupts on the rising edge
[ 6.819492] iio iio:device3: registered magnetometer lis3mdl
[ 6.916260] Bluetooth: Core ver 2.22
[ 6.916376] NET: Registered protocol family 31
[ 6.916380] Bluetooth: HCI device and connection manager initialized
[ 6.916410] Bluetooth: HCI socket layer initialized
[ 6.916420] Bluetooth: L2CAP socket layer initialized
[ 6.916456] Bluetooth: SCO socket layer initialized
[ 6.958482] sun6i-csi 1cb0000.csi: creating gc2145 4-003c:0 -> sun6i-csi:0 link
[ 6.958495] sun6i-csi 1cb0000.csi: creating ov5640 4-004c:0 -> sun6i-csi:0 link
[ 6.966073] Bluetooth: HCI UART driver ver 2.3
[ 6.966087] Bluetooth: HCI UART protocol H4 registered
[ 6.966177] Bluetooth: HCI UART protocol LL registered
[ 6.966249] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 6.967221] dw-apb-uart 1c28400.serial: failed to request DMA
[ 6.967418] Bluetooth: HCI UART protocol Broadcom registered
[ 7.198951] i2c i2c-2: Added multiplexed i2c bus 5
[ 8.279301] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 8.542949] urandom_read: 5 callbacks suppressed
[ 8.542958] random: mktemp: uninitialized urandom read (10 bytes read)
[ 8.983590] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[ 9.363190] modem-power serial1-0: powering up
[ 9.628036] modem-power serial1-0: wakeup ok
[ 10.744219] random: crng init done
[ 12.575842] modem-power serial1-0: status ok
[ 12.576228] dw-apb-uart 1c28c00.serial: failed to request DMA
[ 22.843466] usb 3-1: new high-speed USB device number 2 using ehci-platform
[ 23.081962] usbcore: registered new interface driver cdc_wdm
[ 23.091657] usbcore: registered new interface driver option
[ 23.091725] usbserial: USB Serial support registered for GSM modem (1-port)
[ 23.092091] option 3-1:1.0: GSM modem (1-port) converter detected
[ 23.092545] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 23.092809] option 3-1:1.1: GSM modem (1-port) converter detected
[ 23.094234] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 23.095691] option 3-1:1.2: GSM modem (1-port) converter detected
[ 23.098746] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 23.099017] option 3-1:1.3: GSM modem (1-port) converter detected
[ 23.099878] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 23.111216] qmi_wwan 3-1:1.4: cdc-wdm0: USB WDM device
[ 23.112690] qmi_wwan 3-1:1.4 wwan0: register 'qmi_wwan' at usb-1c1b000.usb-1, WWAN/QMI device, c6:bb:e8:65:3c:e6
[ 23.112837] usbcore: registered new interface driver qmi_wwan
[ 26.581509] modem-power serial1-0: ===================================================
[ 26.581525] modem-power serial1-0: Project Name: EG25G
[ 26.581534] modem-power serial1-0: Project Rev : EG25GGBR07A08M2G_01.001.10
[ 26.581542] modem-power serial1-0: Branch Name: 9x07_R07_NEW
[ 26.581549] modem-power serial1-0: Custom Name : STD
[ 26.581557] modem-power serial1-0: Build Date: 2019-12-03,18:10
[ 26.581566] modem-power serial1-0: Version: SBLR07EG25G01_1:37500: Oct 17 2
[ 26.581573] modem-power serial1-0: Version: TZR07A03: Dec 2 2019
[ 26.581582] modem-power serial1-0: Version: RPMR07A03_1:37500: Dec 2 2019
[ 26.581588] modem-power serial1-0: ===================================================
[ 26.581597] modem-power serial1-0: Your modem has an outdated
firmware. Latest know version is EG25GGBR07A08M2G_01.002.07. Consider
updating.
[ 26.591356] modem-power serial1-0: ADB KEY is '32251809' (you can use
it to unlock ADB access to the modem, see
https://xnux.eu/devices/feature/modem-pp.html)
[ 27.635294] modem-power serial1-0: QDAI is '1,1,0,1,0,0,1,1'
[ 27.647281] modem-power serial1-0: QCFG 'risignaltype' is '"physical"'
[ 27.659370] modem-power serial1-0: QCFG 'urc/ri/ring' is '"pulse",1,1000,5000,"off",1'
[ 27.675268] modem-power serial1-0: QCFG 'urc/ri/smsincoming' is '"pulse",1,1'
[ 27.691291] modem-power serial1-0: QCFG 'urc/ri/other' is '"off",1,1'
[ 27.703313] modem-power serial1-0: QCFG 'urc/ri/pin' is 'uart_ri'
[ 27.715373] modem-power serial1-0: QCFG 'urc/delay' is '0'
[ 27.727336] modem-power serial1-0: QCFG 'sleepind/level' is '0'
[ 27.743366] modem-power serial1-0: QCFG 'wakeupin/level' is '0'
[ 27.755288] modem-power serial1-0: QCFG 'ApRstLevel' is '1' (changing to '0')
[ 27.779290] modem-power serial1-0: QCFG 'ModemRstLevel' is '0'
[ 27.791309] modem-power serial1-0: QCFG 'apready' is '0,0,500'
[ 27.803274] modem-power serial1-0: QCFG 'airplanecontrol' is '1,0'
[ 27.815301] modem-power serial1-0: AT command 'AT+QCFG="fast/poweroff"' returned ERROR
[ 27.839310] modem-power serial1-0: powered up in 18476 ms
[ 31.715157] vbat-wifi: disabling
[ 31.715197] avdd-csi: disabling
[ 31.715260] usb-5v: disabling
Code:[ 27.839310] modem-power serial1-0: powered up in 18476 ms
I see vbat-wifi disabling at the end and rtl8723cs kernel module for wifi doesn't load on turning on the phone or when the phone is rebooted.
ipconfig -a output -
Code:lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:4 errors:0 dropped:0 overruns:0 frame:0
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:288 (288.0 B) TX bytes:288 (288.0 B)
usb0 Link encap:Ethernet HWaddr D6:BC:2F:DA:FA:00
inet addr:172.16.42.1 Bcast:172.16.255.255 Mask:255.255.0.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wwan0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
POINTOPOINT NOARP MULTICAST MTU:1500 Metric:1
I have tried different versions of OS and it is same on all. wifi and bluetooth interface is never started on all.
Anyone here encountered this error? I have tried different options browsing the internet with little, all kinds of help to fix this issue is welcome. Please help!!!
Below 2 error messages in dmesg indicate some issue with hardware -
Any kernel developers here who can debug these messages will be of great help.. Thanks
I get all of those errors and wifi works, so I guess those are unrelated to wifi.
In one of the forums when there was a hardware issue, the mmc1 was not being detected, so even in the dmesg I have shared I dont find mmc1.
Is this the reason why WIFI/BT module is not being detect? Waiting for your reply. Thanks
Code:[ 1.461502] mmc1: new high speed SDIO card at address 0001
