U-Boot, partition layout and flash
I am also looking for the next steps on assembling the pieces after grabbing the SDK and compiling.  Here is what I am seeing from adb connected via the network. Is there more than just dd'ing the products from out/target/product/tulip-t1 or is there some script that I am missing and not running.
root@tulip-chiphd:/ # cat /proc/partitions
major minor  #blocks  name
 253        0     262144 zram0
 179        0   31276032 mmcblk0
 179        1    4971519 mmcblk0p1
 179        2      32768 mmcblk0p2
 179        3          1 mmcblk0p3
 179        5      16384 mmcblk0p5
 179        6      16384 mmcblk0p6
 179        7    1572864 mmcblk0p7
 259        0      16384 mmcblk0p8
 259        1      32768 mmcblk0p9
 259        2     786432 mmcblk0p10
 259        3      16384 mmcblk0p11
 259        4      16384 mmcblk0p12
 259        5      81920 mmcblk0p13
root@tulip-chiphd:/dev/block # ls -l by-name
lrwxrwxrwx root     root              2009-12-31 16:00 UDISK -> /dev/block/mmcblk0p1
lrwxrwxrwx root     root              2009-12-31 16:00 alog -> /dev/block/mmcblk0p13
lrwxrwxrwx root     root              2009-12-31 16:00 boot -> /dev/block/mmcblk0p6
lrwxrwxrwx root     root              2009-12-31 16:00 bootloader -> /dev/block/mmcblk0p2
lrwxrwxrwx root     root              2009-12-31 16:00 cache -> /dev/block/mmcblk0p10
lrwxrwxrwx root     root              2009-12-31 16:00 env -> /dev/block/mmcblk0p5
lrwxrwxrwx root     root              2009-12-31 16:00 metadata -> /dev/block/mmcblk0p11
lrwxrwxrwx root     root              2009-12-31 16:00 misc -> /dev/block/mmcblk0p8
lrwxrwxrwx root     root              2009-12-31 16:00 private -> /dev/block/mmcblk0p12
lrwxrwxrwx root     root              2009-12-31 16:00 recovery -> /dev/block/mmcblk0p9
lrwxrwxrwx root     root              2009-12-31 16:00 system -> /dev/block/mmcblk0p7
root@tulip-chiphd:/dev/block # cat /proc/cmdline
enforcing=1 earlyprintk=sunxi-uart,0x01c28000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p7 init=/init partitions=bootloader@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6Confusedystem@mmcblk0p7:misc@mmcblk0p8:recovery@mmcblk0p9:cache@mmcblk0p10:metadata@mmcblk0p11:private@mmcblk0p12:alog@mmcblk0p13:UDISK@mmcblk0p1 cma=384M androidboot.selinux=permissive androidboot.serialno=8400519008005c1b014b androidboot.hardware=sun50iw1p1
I wonder if part of the solution might be found here:
http://linux-sunxi.org/Boot_Android_from...to_SD_card
So far, I haven't done much other than:
source build/envsetup.sh
make clean
lunch tulip_t1-eng
mka
Any hints would be appreciated. I am missing a big conceptional piece somewhere.
I guess I will use the loop dev next and see what I can see from the linux side.
Thanks in advance for any pointers.
Jim
U-Boot, partition layout and flash - by kap1r0t0 - 05-29-2016, 10:42 PM
RE: U-Boot, partition layout and flash - by Luke - 06-01-2016, 06:51 AM
RE: U-Boot, partition layout and flash - by jad - 06-01-2016, 06:38 PM
RE: U-Boot, partition layout and flash - by jad - 06-02-2016, 12:13 PM
  [PINE A64 2GB Kickstarter]How to boot android from external SSD v1n1c1uS 1 3,438 01-15-2018, 11:05 PM
  Kickstarter edition wont boot to android bilbo6209 1 3,337 01-09-2018, 08:03 PM
  Boot hangs on pine64, how to debug? olh 1 3,604 08-29-2017, 12:04 AM
  Pine64+ 1G: boot loader details required Tanveer 4 6,853 07-29-2017, 09:07 PM
Last Post: Tanveer
  Pine 2GB won't boot Android anymore Bluphire 5 7,684 05-29-2017, 09:34 PM
Last Post: dkryder
  Custom boot animations Bluphire 4 5,790 05-05-2017, 02:00 AM
Last Post: Quezbeme
  Change Android boot logo? ipsw 5 10,932 05-03-2017, 09:39 PM
Last Post: Quezbeme
  Do apps run in the background at boot up? Penfold 3 4,673 03-10-2017, 02:19 PM
Last Post: mporeh
  Partition Table xalius 1 2,988 07-24-2016, 05:08 AM
Last Post: xalius
  Boot up issue... shadow22 9 9,682 06-23-2016, 07:44 AM
Last Post: shadow22
