MMS Download Script
(11-12-2020, 02:44 PM)antiX-Dave Wrote:
(11-12-2020, 01:44 PM)HLing Wrote: AntiX-Dave, Thanks for the work!  I am not quite ready to try this, but in going through the motion I found today with sudo mmcli -L that my modem is no longer 0, but is 6.  (which explains why I was getting error message of not finding the modem, even though my phone voice and data were both working.) So then I continue to check and see if i have any large sms that usually means someone sent me a mms without me knowing.  Literally, within the same hour, with sudo mmcli -i 6 , I get the error message that there is no SIM found.  OK, so I did another sudo mmcli -L , and what do you know, it is now 7, not 6.
Not 100% sure but it sounds like your modem is improperly power cycling and the kernel is seeing it as a new device every time the modem power cycles without seeing the "old" one turning off. Maybe this is a bug when you are toggling mobile service/data on and off? Mine is consistently 0.
If that is the case maybe the script needs to check for the modem over a sequence from 0-10?
So I updated and upgraded after posting the above.  After rebooting, sudo mmcli -L is back to 0.  I think whatever happened had happened yesterday already.  Maybe updating had fixed it.  But, yes, prior to this my modem had also been consistently 0.
MMS Download Script - by antiX-Dave - 11-11-2020, 02:23 PM
RE: MMS Download Script - by DarkManiels - 11-11-2020, 09:47 PM
RE: MMS Download Script - by kng - 11-12-2020, 05:41 AM
RE: MMS Download Script - by Cree - 11-12-2020, 11:28 AM
RE: MMS Download Script - by HLing - 11-12-2020, 01:44 PM
RE: MMS Download Script - by antiX-Dave - 11-12-2020, 02:44 PM
RE: MMS Download Script - by HLing - 11-12-2020, 03:27 PM
RE: MMS Download Script - by fdlamotte - 12-07-2020, 07:08 AM
RE: MMS Download Script - by Gribouille - 12-10-2020, 10:36 AM
RE: MMS Download Script - by kop316 - 12-10-2020, 11:48 AM
RE: MMS Download Script - by Zebulon Walton - 12-10-2020, 03:15 PM
RE: MMS Download Script - by antiX-Dave - 12-13-2020, 11:57 AM
RE: MMS Download Script - by antiX-Dave - 12-12-2020, 06:17 PM
RE: MMS Download Script - by kop316 - 12-12-2020, 06:43 PM
  PureMaps and OSM Scout Server maps download biketool 6 2,602 01-08-2024, 04:11 AM
Last Post: vusra
  Will this battery-saving script cause problems? rp3 1 1,219 08-28-2022, 02:00 PM
  Bookworm Navigation Enabler Script biketool 2 1,537 06-02-2022, 04:12 AM
  "Unable to download updates: The following packages have unmet dependencies:" bitnick 13 12,016 04-23-2021, 09:45 PM
Last Post: ryo
  MAC Address/NIC Privacy Script [various options] RTP 2 3,725 08-17-2020, 09:39 AM
Last Post: RTP
  Download Latest Version through wget/curl pizzalovingnerd 1 3,161 06-20-2020, 03:30 AM
Last Post: rico
