3 Day Old Manjaro Convergence Edition 4 Sale
#21
(11-06-2020, 06:20 PM)NobodyNew1 Wrote:
(11-06-2020, 06:07 PM)rocket2nfinity Wrote:
(11-06-2020, 05:40 PM)NobodyNew1 Wrote: If PMOS is flashed to the eMMC the outcome is txt working, phone calls can come in, calls can go out, BUT I can't hear a call going out or can anyone hear me when a call is answered nor can I hear them.
So, as of now the only OS that seems to work with T-Mobile is PMOS or at least for my phone. I'm going to put random OS's on an SD card and see it the phone still works or works better. Then I think over the weekend, I'll flash every OS onto the phone and see if PMOS is the only one that works or semi-works with T-Mobile.
So, this might not be a hardware issue at all it all might be a T-Mobile issue + OS's, the only thing that is disturbing now is the hearing making and receiving phone calls.
(11-06-2020, 05:31 PM)rocket2nfinity Wrote:
(11-06-2020, 05:16 PM)NobodyNew1 Wrote: I just replaced the SIM day before yesterday, because of this issue. It wasn't the SIM or is it . . . . . . . . .
If your verizon sim works, and two t-mobile sims do not, it's not the sims nor the hardware. It's the network. T-mobile has been making changes. That includes removing towers and bands in certain areas to accomodate 5g. You really should try some free trial or cheap sims with different networks.
What's your thoughts on my post above this one or below it,.
So, your sim does see the network. I was under the impression it didn't. The call audio issue  is known. The only OS I think has that solved is Mobian, and arch for a while. But do keep in mind, the various builds are alpha or beta at most. Things got broken recently to fix other things. Give it a little time for the Dev's to fix the fixes. Mobian for instance is undergoing a big update that will change a lot.
There is a thirteen-in-one OS build in the forums. You can try most of the available builds on one SD with it.
The only OS that sees the ( T-Mobile ) cell network is PMOS, nothing else on a SD Card and the factory installed Manjaro didn't either, nor did Mobian or Arch ( Flashed eMMC ).
I'll search for the 13 OS's and see if I can find it.
That sounds more like an apn issue rather than an OS, sim or hardware issue. Different OSes require different amounts of fiddling to get the network up and recognized. The 13-in-1 had that worked out if i recall correctly. But, things are changing in some builds, so things get broken...
Or it's a hardware update issue as someone above mentioned.
https://forum.pine64.org/showthread.php?tid=11347
RE: 3 Day Old Manjaro Convergence Edition 4 Sale - by MonCon - 11-05-2020, 01:24 PM
RE: 3 Day Old Manjaro Convergence Edition 4 Sale - by rocket2nfinity - 11-06-2020, 06:28 PM
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,886 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,759 12-22-2023, 03:44 PM
  box86 Actually Works Well on Manjaro Phosh/xfce jakfish 0 648 07-13-2023, 02:39 PM
Last Post: jakfish
  no sdcard boot and manjaro update failed Gwen 3 1,436 11-27-2022, 07:56 AM
Last Post: fxc
  Pinephone for sale in Europe tiho 7 5,525 10-19-2022, 05:35 AM
Last Post: peatord
  Tow-boot on Pinephone beta edition saddamus 10 5,467 09-11-2022, 02:43 PM
Last Post: saddamus
Rainbow New Pinephone for sale, Beta w Convergence Package megst 0 767 07-26-2022, 11:40 AM
Last Post: megst
  Manjaro phosh no screen rotation sandspur 1 1,351 06-23-2022, 01:02 AM
Last Post: rapp
  WTS: (Rarely used) Pinephone Beta Edition with Convergence Package - DHL shipping vatin 3 2,008 05-25-2022, 04:31 PM
Last Post: vatin
  Selling Pinephone PostmarketOS Convergence Edition pentamassiv 0 1,086 03-22-2022, 06:33 PM
Last Post: pentamassiv
