Proper way to use mrfixit update
xzcat should work OK, saves wear and tear on SD (writing extracted image),,
bs speed depends on a lot of things, I would say 64k is minimum for good performance,
somebody did a test and results were hardly determinate
Not surprising, there are about 4 variables
iozone gives a good clue
of= should be to ENTIRE block device, right?,, not to a partition
(and you do have to be root, or sudo both sides of pipe)
and what's the thing about mrfixit_update.sh,, you know that is ONLY for that distro?
Proper way to use mrfixit update - by bastafari - 09-28-2020, 10:11 AM
RE: Proper way to use mrfixit update - by KC9UDX - 09-29-2020, 11:09 AM
RE: Proper way to use mrfixit update - by KC9UDX - 09-29-2020, 12:44 PM
RE: Proper way to use mrfixit update - by KC9UDX - 09-29-2020, 01:39 PM
RE: Proper way to use mrfixit update - by wdt - 09-29-2020, 02:59 PM
RE: Proper way to use mrfixit update - by wdt - 09-29-2020, 03:58 PM
RE: Proper way to use mrfixit update - by KC9UDX - 09-29-2020, 07:10 PM
RE: Proper way to use mrfixit update - by wdt - 09-29-2020, 09:45 PM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,251 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 1,054 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 1,066 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,336 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,432 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 2,110 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 5,986 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 1,382 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 2,591 10-19-2021, 01:57 AM
Last Post: j4n3z
  Trackpad firmware update Luke 263 361,754 07-28-2021, 12:52 PM
Last Post: Luke
