Battery that drains even with the Pinphone turned off
Quote:If proper power down is to be implemented in the kernel for the modem, to allow safe shutdown of the modem before turning off the 4g-pwr-bat, kernel has to be able to signal to the modem to shut down and wait 30s.
This is not possible on braveheart.
Without this signal, kernel can't do anything to shut down the modem, and would have to rely on userspace to properly manage the modem power up/down sequence. Relying on userspace risks users shutting down the modem without proper wait time of 30s, risking modem damage (flash data corruption).
I believe on PMOS they still wait 30 seconds for shutdown even on 1.2a.
It's not necessary on the latest Quectel firmware, it safely shuts down in 2s. The question is only if it's getting the shutdown message.
RE: Battery that drains even with the Pinphone turned off - by lot378 - 09-25-2020, 05:24 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 608 02-17-2024, 04:15 PM
Last Post: vortex
  Battery life improvement freelectro 10 3,504 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,585 03-20-2023, 12:54 AM
Last Post: bcoyle
  Power supply vs battery albafrati 11 4,814 06-22-2022, 06:04 PM
Last Post: albafrati
  What PD charger/dock combo results in PP battery not draining while using convergence james8880 0 1,501 04-28-2022, 12:45 PM
Last Post: james8880
  Battery mot charging past 54% StickyPine 32 26,752 02-26-2022, 02:07 AM
Last Post: vusra
  Battery replacement alternative sax1960 7 6,450 08-29-2021, 07:03 AM
Last Post: bcnaz
  Battery Capacity and Software Interaction food 2 2,483 08-15-2021, 07:19 AM
Last Post: bcnaz
  Battery phone case expected? Cpm 1 2,138 08-10-2021, 03:29 PM
Last Post: 33YN2
  Pine Phone Battery Issue vslash 21 19,220 08-09-2021, 07:35 AM
Last Post: mouffa
