SD card wrong space
I'm guessing that what you're seeing is a 128 MB/121 MiB boot partition. It's likely that the main partition is using an ext4 filesystem, and as far as I know (I haven't used Windows for ~10 years) Microsoft has choosen not to support this filesystem (since support would make it easier for Linux-based and Windows-based computers to co-exist, which is of course a threat to MS.)
My Mobian SD card actually use ext4 for both boot and main partitions, so Windows would probably show that card as having no valid partitions at all.
There are apparently 3rd-party tools for accessing linux file systems from Windows, but I'm not familiar with them/don't know how well they work. A better option might be to install and dual-boot linux on your PC and access both your SD card and your Windows NTFS file system from the Linux OS.
SD card wrong space - by Cree - 08-31-2020, 10:59 AM
RE: SD card wrong space - by bitnick - 08-31-2020, 03:30 PM
RE: SD card wrong space - by z4v4l - 08-31-2020, 03:56 PM
RE: SD card wrong space - by bitnick - 08-31-2020, 08:10 PM
RE: SD card wrong space - by z4v4l - 09-01-2020, 02:41 PM
RE: SD card wrong space - by bitnick - 09-01-2020, 07:22 PM
  Wrong GPS Position derbaertigefrytz 1 984 09-03-2023, 02:43 PM
Last Post: alaraajavamma
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 24,408 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 3,512 05-25-2022, 03:26 PM
Last Post: sfb
  Largest supported micro SD card? zooidic 2 2,061 01-08-2022, 06:01 AM
Last Post: zooidic
  Red LED when trying to boot from SD card. Need advice. サーバント 5 4,315 10-20-2021, 09:40 AM
  Fragile SIM card connector hakkou 1 1,850 08-25-2021, 07:44 AM
Last Post: wibble
  Sd card slot death? Hurrikan 7 6,642 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  WARNING to future users ~ Order yourself a SIM Card Extender Bonesdog 3 4,039 05-03-2021, 10:06 AM
Last Post: Bonesdog
  Strange SD Card Problems anhilde 7 6,508 02-21-2021, 07:52 AM
  Fastest SD card happybot-4678 9 8,701 02-20-2021, 01:08 AM
Last Post: dsimic
