battery usage
(08-28-2020, 01:00 PM)jed Wrote: The Mobian Project openly admit that battery life is poor; power management isn't a development focus.
You can start charging the phone, then turn it off (it continues charging) to reduce heat; using your phone while it charges will generate excess heat and put a parasitic load onto the battery. PINE64 sell a battery charger for $5 which will also eliminate heat - buy a spare battery and hot swap them.
Hi Jed, thanks for your reply!  I will try not to use the phone while charging, although, I don't want to miss a call or text at that time.  I did try to get the battery charger and a spare battery a while back. I just checked again, the charger is available, but the spare battery is still "out of stock" Sad
battery usage - by HLing - 08-28-2020, 12:08 PM
RE: battery usage - by User 18618 - 08-28-2020, 01:00 PM
RE: battery usage - by HLing - 08-28-2020, 01:17 PM
RE: battery usage - by User 18618 - 08-29-2020, 06:04 AM
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,195 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 2,413 11-28-2022, 10:58 AM
Last Post: 3x5co
  Will this battery-saving script cause problems? rp3 1 1,218 08-28-2022, 02:00 PM
  Battery Management jsch 4 2,061 07-27-2022, 11:17 AM
Last Post: jsch
  Electricty Usage Efficiency food 7 5,181 09-18-2021, 01:17 PM
  Limiting battery charging to some percentage TRS-80 3 3,221 08-22-2021, 01:02 AM
Last Post: bcnaz
  Increasing max voltage to use a bigger battery SocialNetworkingWasAMistake 4 3,927 06-09-2021, 09:59 AM
Last Post: wibble
  Possible fix for lousy standby battery life? bitnick 5 5,192 02-04-2021, 04:05 PM
Last Post: dcinoz
  SMS after dead battery antiX-Dave 4 6,036 06-05-2020, 08:11 PM
Last Post: antiX-Dave
