New UBports edition - black screen (backlight) only
(08-03-2020, 09:45 PM)BBreeziN Wrote:
(08-03-2020, 09:43 PM)SwordfishII Wrote:
(08-03-2020, 07:17 AM)BBreeziN Wrote:
(08-03-2020, 03:56 AM)drpi Wrote: Flicker is a known problem at boot time.
Keep your phone connected on the charger for some time. Then try to boot it again.
Thanks for the fast reply, but it's not just flickering anymore, the screen never comes on at all. I left it plugged in overnight, but it still will not do anything (no LEDs, backlight, nothing) without being plugged in. It kind of seems like there are two issues here, the screen not working, and now the battery not charging or working.
Might be a silly question... But did you pull out the plastic tab covering the battery terminals?
You have to pop the back cover and remove the plastic barrier on the battery. Seems like that would cause the screen to not work and the battery to not charge if it's still in place.
Yes I did. It was holding a charge, running off the battery, and indicating a 90% battery during the 1 or 2 boot cycles where the screen was actually working. Any other ideas?
Bad battery or the orientation of the battery is wrong maybe. Do you have a multimeter to check the battery and the pins on the phone while plugged in?
If not you could get a new battery to eliminate or more likely confirm the battery as the issue
RE: New UBports edition - black screen (backlight) only - by SwordfishII - 08-03-2020, 09:50 PM
  Screen dying already? marcih 156 217,082 06-12-2025, 06:18 AM
Last Post: mikeb
  Screen Replacement Instructions erikkugel 5 6,325 02-24-2025, 06:55 AM
Last Post: anonymous
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 1,094 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 3,687 10-12-2023, 01:03 PM
Last Post: robthebold
  No calls on Pine Phone Beta convergence edition polypode 1 2,065 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 33,949 01-29-2023, 12:20 PM
Last Post: skandigraun
  BETA edition rcu errors 8bit 29 30,853 11-02-2022, 01:40 PM
Last Post: some_pinephone_user
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 5,654 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 2,972 07-03-2022, 06:27 AM
Last Post: Avisando
Question Upgrading a 2020 Community Edition Pinephone? danimations 5 5,920 03-10-2022, 08:18 AM
Last Post: danimations
