Modem UBports edition Celluar not working
(08-04-2020, 07:09 PM)LazLong Wrote:
(08-01-2020, 06:38 PM)bcnaz Wrote: Curious,  have you attempted to use the software update feature on Mobian O.S. with the 'firmware updates' checked ?
  Top right corner of the main software page, under preferences ?
    You said your wifi is working  ?   * * *  (  I am not a tech, so my ideas could be mistaken )
 I asked for more information about those choices in another thread,  but I have not got a response to that post yet.
  I am thinking this could likely be a firmware problem....  The Brave Heart seems to be affected more than the Community Editions.???
I took your suggestion.  I had not been running the updates but did so with the 8-2 and 8-3 Mobian nightly builds.  The sim is still not being detected.  Went back and tried it in the newer PostMarketOS factorytest version and same negative result that the sim card was not found.
Apparently, my situation is rather unique or rare in that no one else seems to be experiencing a complete failure of there Braveheart to pass the EC25 factorytest or to detect a working sim card in multiple OS's (UBPorts, Mobian, PureOS, and PostMarketOS).
Dissapointed but if that is the case as evidenced by few if any other reports of this problem with the Braveheart then I guess I'll be relegated to waiting for the new PinePhone with Convergence and hopefully will have much better luck with it since there are several modem related hardware fixes in that V1.2 mainboard revision.
Anyone know when a V1.2 replacement mainboard for the Pinehone might be available in the store for those of us for one reason or another that could use one?
  Are you certain of your sim card itself ?
   I am unable to activate a new sim card in my Brave Heart,
but it does work fairly well with the sim card I removed from my Android phone.
RE: Modem UBports edition - by rocket2nfinity - 07-28-2020, 07:46 PM
RE: Modem UBports edition - by FOSSagent0 - 07-28-2020, 11:34 PM
RE: Modem UBports edition - by LazLong - 07-31-2020, 11:57 PM
RE: Modem UBports edition - by bcnaz - 08-01-2020, 03:52 AM
RE: Modem UBports edition - by LazLong - 08-01-2020, 04:30 PM
RE: Modem UBports edition - by bcnaz - 08-01-2020, 06:38 PM
RE: Modem UBports edition - by SwordfishII - 08-01-2020, 07:43 PM
RE: Modem UBports edition - by LazLong - 08-04-2020, 07:09 PM
RE: Modem UBports edition - by bcnaz - 08-05-2020, 05:21 PM
RE: Modem UBports edition - by bcnaz - 08-01-2020, 08:29 PM
RE: Modem UBports edition - by SwordfishII - 08-01-2020, 11:56 PM
RE: Modem UBports edition - by fins - 08-05-2020, 01:10 PM
RE: Modem UBports edition - by LazLong - 08-05-2020, 06:21 PM
RE: Modem UBports edition - by bcnaz - 08-05-2020, 07:29 PM
RE: Modem UBports edition - by FOSSagent0 - 08-12-2020, 07:13 AM
RE: Modem UBports edition - by bcnaz - 08-12-2020, 09:06 PM
RE: Modem UBports edition - by bcnaz - 08-15-2020, 02:26 PM
  Supported Carrier and Modem Bands NachoMomma 4 1,592 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 543 02-17-2024, 04:15 PM
Last Post: vortex
Bug PinePhone modem keeps "disappearing" Kevin Kofler 14 5,663 03-22-2023, 05:28 PM
  No calls on Pine Phone Beta convergence edition polypode 1 1,179 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  modem not working michelinux 0 931 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 4,239 02-15-2023, 11:17 AM
Last Post: fxc
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 24,020 01-29-2023, 12:20 PM
Last Post: skandigraun
  BETA edition rcu errors 8bit 29 20,062 11-02-2022, 01:40 PM
Last Post: some_pinephone_user
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,658 07-25-2022, 07:35 AM
Last Post: bedtime
  firmware udate Quectel EG25-G modem alwi 7 5,398 07-06-2022, 01:43 PM
Last Post: user641
