Is there a none-headless Linux OS that really works now for Rock64?
(07-09-2020, 08:34 PM)nethammer Wrote: I've not run FreeBSD (pfSense) on the Rock64, only ArchLinuxARM. IMO, Linux is a fully capable, advanced firewall, just without the pfSense GUI.
A big reason why pfSense adopted FreeBSD is licensing (BSD vs. GPL2). That said, I'm not diminishing FreeBSD in any way, it's VERY capable, too.
I use the Rock64 boards as very complex VPN routers (huge rule sets) and they run basically wire-speed. I first setup a Rock64 in an emergency, replacing some X86-64 and big Cisco hardware, after a severe hurricane with unexpected backup power failure. I ultimately had a VERY LIMITED power budget for a couple weeks. I was thoroughly amazed at how well the Rock64's performed---so amazed that I've never gone back to the x86 systems, except where I need 10GigE and 40GigE wire-speed. I still use Cisco at the high end, for wire-speed layer 3 filtering/routing.
Ah, so it's for way more advanced stuff. Pretty cool how you ended up using these SBCs because of power failure. I don't have the time to learn and work on a project like that, so I'll just have to sell my Rock64.
Thanks for the replies.
RE: Is there a none-headless Linux OS that really works now for Rock64? - by AkiraSensei - 07-09-2020, 09:13 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 152 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,370 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 616 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 612 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,408 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,641 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,754 06-02-2023, 07:52 AM
Last Post: diederik
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
