Arch Linux ARM on PinePhone
#90
(11-23-2020, 08:41 AM)wibble Wrote: I think you misunderstood the AGPS part - it needs to be done every time you need to get a first fix quickly, not just once.  The data it uploads is valid for a limited time period. The persistent part is the 'AT+QGPSXTRA=1' setting which needs a modem restart to take effect if changed.
Also the script is very much proof-of-concept - if you're using it regularly you can streamline it by removing the checks that aren't acted on to save a few seconds of waiting for timeouts.
Thank you, yes I had misunderstood. Do you know where I can find the schedule for data releases? I am not sure if I will need to use it but .....
Mobile data has returned, even after deep sleep most times (5 out of 7), it will not shut off now when the wifi comes up. I don't know if it is supposed to.
The story, while trying to set the modem up improperly I got frustrated and incorrectly entered the command:
AT+FU  The modem responded with Ok
With a big grin on my face I entered the command numerous times receiving an Ok each time. When i checked I had cellular data Smile
The truth is I have no idea what I did but at least one of my commands was effective, time for " history|less"
LF
Arch Linux ARM on PinePhone - by Danct12 - 06-30-2020, 08:08 PM
Power drain - by jmorris - 10-04-2020, 12:29 AM
RE: Arch Linux ARM on PinePhone (2020/11/12) - by Lousy Fisherman - 11-23-2020, 10:34 AM
RE: Arch Linux ARM on PinePhone - by linmob - 07-26-2021, 02:04 AM
RE: Arch Linux ARM on PinePhone - by mouffa - 07-25-2021, 04:27 AM
RE: Arch Linux ARM on PinePhone - by bcnaz - 09-22-2021, 06:22 PM
RE: Arch Linux ARM on PinePhone - by AndyM - 09-23-2021, 12:17 AM
RE: Arch Linux ARM on PinePhone - by bcnaz - 09-23-2021, 01:28 AM
RE: Arch Linux ARM on PinePhone - by AndyM - 09-23-2021, 04:27 AM
  Updating Arch Linux _radv_ 8 879 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,303 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 819 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,985 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,889 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 933 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 859 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 2,177 11-07-2022, 04:38 PM
Last Post: Ferriah
  Latest version Arch Plasma looks good. Chief 5 2,480 10-23-2022, 01:53 PM
Last Post: Chief
  Evolution no longer runs on Arch Phosh. Chief 2 1,432 10-17-2022, 07:22 AM
Last Post: Chief
