Arch Linux ARM on PinePhone
(07-11-2020, 02:04 PM)Danct12 Wrote: [*]Added a flashlight app, now you can find your lost keys in the dark!
do you need to reflash or is updating enough? I'm not able to locate a flashlight app, either in the menu, nor in the software manager
also, there is a sizing issue where apps ignore the existence of both the top and bottom bars and just grow their UI to whatever size anyway. the bottom bar is ignored by most apps, and the top bar is ignored by most pop-up windows
edit: to add the flashlight app, install "flashlight" using pacman. it's located in the phosh repository. note: it appears to be non-functional
Arch Linux ARM on PinePhone - by Danct12 - 06-30-2020, 08:08 PM
RE: Arch Linux ARM on PinePhone (2020/07/05) - by hiimtye - 07-12-2020, 12:58 PM
Power drain - by jmorris - 10-04-2020, 12:29 AM
RE: Arch Linux ARM on PinePhone - by linmob - 07-26-2021, 02:04 AM
RE: Arch Linux ARM on PinePhone - by mouffa - 07-25-2021, 04:27 AM
RE: Arch Linux ARM on PinePhone - by bcnaz - 09-22-2021, 06:22 PM
RE: Arch Linux ARM on PinePhone - by AndyM - 09-23-2021, 12:17 AM
RE: Arch Linux ARM on PinePhone - by bcnaz - 09-23-2021, 01:28 AM
RE: Arch Linux ARM on PinePhone - by AndyM - 09-23-2021, 04:27 AM
  Updating Arch Linux _radv_ 8 867 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,288 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 813 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,975 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,886 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 930 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 856 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 2,167 11-07-2022, 04:38 PM
Last Post: Ferriah
  Latest version Arch Plasma looks good. Chief 5 2,475 10-23-2022, 01:53 PM
Last Post: Chief
  Evolution no longer runs on Arch Phosh. Chief 2 1,421 10-17-2022, 07:22 AM
Last Post: Chief
