Creating a current armbian-Image with network-fix
In order to make this a a little more update resistant, you might find the following script useful
#!/bin/bash
DTB_NAME=sun50i-a64-sopine-baseboard.dtb
DTB_PATH=/boot/dtb/allwinner
TMPFILE=/tmp/tmp.dts
NEWFILE=/tmp/new.dts
clean_up() {
        rm $TMPFILE $NEWFILE > /dev/null 2>&1
if [ ! -f $DTB_PATH/$DTB_NAME ]
then
        echo dtb file not found
        exit 999
fi
dtc -I dtb -O dts -o $TMPFILE $DTB_PATH/$DTB_NAME > /dev/null 2>&1
if [ $? != 0 ]
then
        echo Cannot extract dts from $DTB_PATH/$DTB_NAME
        exit 998
fi
retcode=0
grep 'allwinner,tx-delay-ps' $TMPFILE > /dev/null 2>&1
if [ $? != 0 ]
then
        sed -e '/ethernet@1c30000 {$/,/phandle = <0x88>;/!b;/phandle = <0x88>;/a\\t\t\tallwinner,tx-delay-ps = <500>;' $TMPFILE > $NEWFILE
        if [ $? != 0 ]
        then
                echo Could not update temporary DTS file
                retcode=997
        else
                dtc -O dtb -o $DTB_PATH/$DTB_NAME -b 0 $NEWFILE > /dev/null 2>&1
                if [ $? != 0 ]
                then
                        echo Could not create new dts file
                        retcode=996
                fi
        fi
else
        echo Fix already in place
fi
clean_up
exit $retcode
This will check whether the supplied update is in place, and, if not, apply it using SED.
How you use this is up to you - perhaps putting a call to it in rc.local... If the card boots, and the fix is not present then it will be applied and all should be well for the next boot.
If you want to test it first on a mounted image, simply adjust the value of DTB_PATH.
I hope that it is found useful, but use as your own risk, no guarantees of any sort etc etc
RE: Creating a current armbian-Image with network-fix - by Dippywood - 09-07-2020, 05:01 AM
Sad Version/Date of last armbian build that came with network patches? Bazmundi 0 275 12-07-2023, 03:23 PM
Last Post: Bazmundi
  Clusterboard not getting IP address after network fix Norlark 14 12,874 08-30-2021, 05:00 PM
Last Post: poVoq
  ArchLinux Network Booting xblack86 2 3,946 02-25-2021, 08:42 AM
Last Post: xblack86
  Clusterboard Armbian aww 17 23,429 07-01-2020, 02:40 PM
Last Post: wayward83
  Network problems (actually bad power supply) Unkn0wn 14 17,743 12-01-2019, 10:02 AM
Last Post: venix1
  Armbian Bionic 4.19.y PigLover 1 2,669 02-02-2019, 02:30 PM
Last Post: mdmbc
