Deep Learning Framework
(06-22-2020, 04:22 PM)Syonyk Wrote: It's Linux.  If you can't find what you need, build it and install it.  There's some stuff that doesn't work properly on 64-bit ARM, but it's fairly rare in actively developed software.
What are you missing?  It might be that Manjaro isn't a good base to work with for this sort of development.  If that's the case, you could consider one of the other Linux distros built for the PBP.
But I'm not specifically familiar with those frameworks, sorry.
I guess that's what I will try, build and install.
Deep Learning Framework - by Hemingway - 06-22-2020, 09:18 AM
RE: Deep Learning Framework - by Syonyk - 06-22-2020, 04:22 PM
RE: Deep Learning Framework - by Hemingway - 06-22-2020, 04:34 PM
  ARM v8 learning setup the_hiacer 7 8,979 04-20-2020, 06:29 PM
Last Post: xmixahlx
