Hey
There is no real difference from an end users perspective. Phoenix card is arguably a bit easier to use (doesnt use fixed-size images) and gives feedback (error messages) if a burn fails. I have, however, had some problems with Phoenix in the past (I haven't tried it in a while, so perhaps its changed since then). I also remember that Phoenix had a bit of lag/ stutter during first boot for a few min that I never experienced with DD.
If you use a Windows machine, use the win32imager; if you are on linux you can use the terminal or the 'restore disk image' function in disk utility.
Hope this helps
Hope this helps
